E34 (1989 - 1995)
Old 11-28-2012, 02:41 PM
CG92 CG92 is offline
Mein Auto: 1994 530i
Help with emissions!
my 1994 530 with an m60b30 has just failed emissions horribly
I recently purchased this car for a good deal and have been fixing it up here and there with my 95 540 parts car
Using a peake research code reader it was throwing four codes, lambda control 1, lambda control 2, O2 sensor 1, and O2 sensor 2
So far I have changed the spark plugs and coil boots, cleaned the ICV and MAF sensor, and have a ccv on its way in the mail and just bought a fuel filter which hasn't been put it in yet, and changed the crank sensor which is reading ohms in spec according to troubleshooting manual
at times it can idle a little rough specially when cold and when hammering on the gas at around 3500 to 4800 rpm it bucks and hesitates as if there were a misfire
I am new to owning a BMW so any help would be great, I thought about replacing o2 sensors but would like some advice before spending more money
Old 11-28-2012, 03:17 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
just a question:
If your car tells you the O2 sensors are shot, then why would you even create a user name to post from before replacing those. The car just told you the answer. O2 sensors can and will end an emission test very abruptly.
EDIT:
welcome to the 'fest
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 11-28-2012, 06:30 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Originally Posted by 95 E34 View Post
just a question:
Seems pretty obvious to me
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 11-28-2012, 06:39 PM
Banned
Mein Auto: car
just a question:
EDIT:
Padre, what would happen if he pulled out the relay for his o2 sensors and deactivated them and deleted all error codes? Would the car somehow compensate in other ways such that he still passes emissions, but perhaps just does not run optimally (assuming other sensors are not shot)? How did non o2 sensor cars pass emissions ?
Old 11-29-2012, 10:03 AM
Monsignor's Avatar
Mein Auto: Sig
none O2 sensor cars are historic and dont require emission.
He could just replace his O2 sensors as regualr maintenance of any car would dictate and continue from there. I think I scared him away anyway, so oh well.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-29-2012, 04:06 PM
Banned
Mein Auto: car
He richly deserved it.....
530, 540, ccv, e34, emissions, lambda, m60, o2
