white smoke - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 11-28-2012, 05:55 AM
matt525 matt525 is offline
Mein Auto: 1994 525i
Cool white smoke
I have white smoke coming out my exhaust on 94 525i i know little about cars but i would to get an idea of the potential causes. The smoking stops after engine is and operating temp. Any info will be helpful thanks
Old 11-28-2012, 05:57 AM
It stops when temp is at operating range
Old 11-28-2012, 06:03 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Sounds like the typical condensation from a cold engine/exhaust during warm up.
Does it smell sweet?
Are you losing coolant?
Have you checked the spark plugs for color variation?
Probably nothing but, if you are worried I can reccomend several more tests You can even buy a chemical test for your coolant to see if combustion gasses are present. Still, I would check the free things above first.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 11-28-2012, 06:31 AM
Banned
Mein Auto: car
Watch your coolant levels. If they drop rapidly and faster than you arr accustomed to, then you need to do many tests. It sounds like alot of condensation due to a sudden change in weather which is why you are concerned.
Please watch your temp gauge more closely while driving until you have put this issue to rest.
Old 11-28-2012, 07:40 AM
I only had the car for 4 weeks and i had to add coolant yesterday wish i had of check it on day one but i will keep an eye on it. It hasnt ran hot or anything idk but its not cool be driving bimmer that smokes no matter the year
Sent from my DROID BIONIC using Bimmer App
Old 11-28-2012, 07:49 AM
Banned
Mein Auto: car
Coolant levels may drop quickly to the cold mark (halfway up the expansion tank). This is alright. However, once it is near the halfway mark, it should be stable, and if it falls, it should be very slow....like you'll need a topup once every 6-8 weeks or something like that.
Old 11-28-2012, 12:55 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
I wouldnt have thought anything of this, all of my cars do this, but topping off the coolant does throw a flag.
I'd keep and eye on it for a little while, notice the rate of coolant loss if any, also, i have "pee-pads" under all my cars to see what theyre leaking or where from and how much, i suggest a box with a towl on it, or just a white flattened box, like i use. Maybe your car is just dripping it from somewhere rather than consuming it.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 11-29-2012, 10:26 AM
S406 S406 is offline
Mein Auto: 00 S4, 93 525i
I live in montana and mine does it terribly until the condensation steams away. Look and see if its leaving a water puddle on the ground from the tail pipe. I had the same concern until I noticed the puddle
