E34 (1989 - 1995)
Old 06-09-2013, 11:25 AM
jvmcdarby jvmcdarby is offline
Mein Auto: 545i
back up lights
Just had the back up lights go out in my 1995 540i. Anyone know where the back up light switch is located . Lights and fuse are good ? Thanks
Old 06-09-2013, 12:08 PM
johnqh johnqh is offline
Mein Auto: 540i
A common issue with 540i is that the wires in the trunk harness wear out. You need to cut open the harness to see it. Supposedly simple fix. It is locked in the trunk, on the left side, right at the trunk hinge.
One of my back up lights and a license plate lights are out. Also the trunk no longer locks with the central locking system. I haven't gotten the time to open the harness to do the fix, but will soon.
Old 06-10-2013, 12:29 AM
filnguyen filnguyen is offline
Mein Auto: 525i
i didnt realize my reverse light was out until i ordered LED bulbs to replace them cause i thought the stock bulbs wasnt bright enough only to find out they never worked. haha did the search and read about the wires breaking/cracking in the trunk. checked it and there was about 6 wires that needed to be fixed, really thought that would fix my reverse problem but it didn't. #12 fuse in the front box was still good as well. so i'm guessing for me its actually the switch that went bad..... but i heard its not a cheap fix. debating if i should spend the money to get it fixed.
Old 06-10-2013, 01:09 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
if its a manual then it is on side of the gearbox itself. if its an automatic, it is part of the shifter lever, you will need to remove the floor plate in the center console
E30 above Sold
Last updated 2nd January 2014
Old 06-10-2013, 11:03 AM
Mein Auto: 545i
back up lights out
Thanks, will look for it there. As for the switch being costly, it can be bought on ebay for about $10, so the only problem with the fix should be finding it
Old 06-10-2013, 11:11 AM
Mein Auto: 525i
Jvm, really? Thanks for the info. I will look Into purchasing one as well. Hopefully having a car lift with make it easier for me to locate the switch. Thanks again
Old 06-10-2013, 11:26 AM
Mein Auto: 545i
back up lights out.
From what I gather, the switch is located under the shifter console IN the car if you have an automatic, if you have a manual then it is on the tranny
Old 06-10-2013, 12:09 PM
Mein Auto: 525i
yeah i have manual so i guess i'll be ordering that part this week and install in once it comes in.
Old 06-10-2013, 12:17 PM
Mein Auto: 525i
do you happen to know the name of the switch that i'm looking for? and is there is a difference for automatic and manual? thanks
Old 06-10-2013, 02:06 PM
Mein Auto: 545i
back up light out
I found one on Ebay under "back up light switch bmw 540i". You mentioned you have a manual.Does it show you the switch and what exactly is the name of the manual . I have the bently which is great but alas no switch info :
Old 06-10-2013, 06:48 PM
Jay. Jay. is offline
Mein Auto: E34
Its called a gear selector switch/safety neutral switch on automatics. It could possibly be called something similar on manuals but im not sure. Check on rock auto.com Thats the cool thing about rockauto is you can look up the part. and if its in stock they will have a picture of it. You might want to try a junkyard. Brand new I think they run about $100. But I just got one for my automatic this weekend and it took me about 10 5 series to find a descent switch. good luck.
'91 525i - Drove it till the wheels fell off
'89 325i - Sold(Drop top on 20" rims)
'93 325i - Totaled
'97 740i - sold
'87 325es with chip - Sold(one of the worst mistakes of my life)
'86 325e - Sold
'90 525i - Current daily driver
I bought a Honda ONCE...
Old 06-10-2013, 07:11 PM
Mein Auto: 525i
i checked the junk yard around my area. less then a handful laying in the junkyard. i wonder if anyone on here and let me know if automatic and manual use the same switch.
Old 06-10-2013, 10:10 PM
Mein Auto: E34
No it will not be the same switch. Heres a pic attached. The switch is the black thing to the right. I thought somebody said it was under the floor board on a manual?? I dunno though..
'93 325i - Totaled
'97 740i - sold
'86 325e - Sold
Old 06-11-2013, 01:22 AM
manual can only be acessed from under the car. it is on the side of the gearbox toward the back, cant remember if it is the left or the right side, its been a while, but should be pretty obvious, its circle shaped, approx the size of whatever your smallest coin is called in USA. Not cross compatible between manual/auto tho.
i think the correct terminology in the BMW system is back up light switch.
plug your chassis number into realoem and find it in the parts lists that come up, will be there somewhere.
E30 above Sold
Old 06-11-2013, 04:07 AM
Mein Auto: 525i
Thanks everyone for your input and help. I hope I'll be able to find what I'm looking for. It's hard fr me
To find time for Everything when I work 7 days a week unless I choose to take a day off. Really appreciate you guys taking your time to help me out as
Much as possible
Old 06-11-2013, 09:33 AM
Mein Auto: 545i
back up light out.
Spent a while last night checking out the wiring diagram and if I am right a good way to check if the problem is the tranny switch, is put the car in reverse and if the passenger mirrow tips down ( as it should ) the problem has to be in the wiring at the back in the trunk ( blue/yellow wire in the harness).. The reason I say this is when the car is in reverse a signal is sent to the mirror and the reverse lights by the switch, so if the mirror gets the signal and the lights does not, the problem cannot be the switch as that signal ( power) is carried from the switch by the same wire before splitting up . Anyway my logic :o).
Old 06-11-2013, 09:54 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Sounds reasonable as long as your mirror has that function (which I think yours does). Also, my E38 had it and there was a button that had to be in a certain position to activate the function. I can't remember where the switch was, but if you have it, make sure that the switch is in the correct position to ensure that your testing method is accurate.
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-11-2013, 11:09 AM
Mein Auto: 525i
Yeah I don't think my car that the tilting side mirror function. I wouldn't know I guess cause my switch to adjust them don't even work. On my todo list haha
Old 06-11-2013, 11:56 AM
Mein Auto: 545i
back up lights
Found out why my back up lights did not work. I am ashamed to have to say this but after I chased every possible cause from the tranny to the bulbs I found BOTH bulbs were caput. I must have been working on one for some time and only when the second went out did I notice I had a problem. Anyway I now have both lights working again and have learned a lot about how that system works, also learned when a light goes out check the bulb first dummy :o). Thanks everybody, thanks to you all I am now a more informed idiot !!!
Old 06-11-2013, 02:35 PM
Mein Auto: 525i
Lol well at least it was an easy fix. I wish mine was an easy fix haha
Old 06-11-2013, 03:16 PM
BMR_LVR's Avatar
Humble E34 lover
Yeah, it happens to all of us at one time or another
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-11-2013, 04:02 PM
Mein Auto: 545i
back up lights
well I suppose my lights are working but my ego took a big hit LOL:
Old 06-11-2013, 05:36 PM
Mein Auto: 540i
LOL, I wish mine can be such a easy fix!
Old 06-11-2013, 10:36 PM
ha, i dont even sugest the bulbs usually because there is two of them, very unlickley to blow at the same time!
i wasnt aware E34 had side mirrors that drop down, thought that only started much later
E30 above Sold
