Old 11-18-2012, 06:56 PM
Stonehauler Stonehauler is offline
Mein Auto: 13 F10/06-330i/11-F350
measuring oil level
I know BMW uses a sensor to measure the oil level in the car, but is there any way to determine the level of the oil either manually, or with the car turned off. My reason for asking is that the oil guage on my car has been slowly going down over the past few weeks, approaching the point where I would add a quart. Today, it rebounded to almost full. With the way BMW measures the oil (with the car on), it doesn't seem like it would be able to accurately tell how much oil is in the car, and you run into the possibility of overfilling.
I suspect that the reasons behind the measurement error is that I drive on roads that are not exactly flat. Compound this with the fact the engine is running, and you are constantly shifting, I would think it would be hard to get a good measurement.
Anyone else have this problem?
2013 BMW 550i M-Sport - ZCW, ZDH, ZEC, ZMP, 2TB
2011 Ford F350 Crew Cab Short bed
2006 BMW 330i Premium, Sport, Automatic, Comfort Access
Retired
2004 Lexus GS 430, 2001 GMC Yukon, 1999 Pontiac Grand Prix GTP, 1997 Ford Thunderbird V-8
Old 11-18-2012, 07:31 PM
tadtaggert tadtaggert is offline
Mein Auto: M6 F12
It's fine, just wait for the message that you need to add a quart, and do so. Other than that if you want to go further, just have the dealer change it. A quart low isn't low, just the point where you can add a quart.
Old 11-18-2012, 08:29 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
Tha gauge seems to have quite a bit of buffering, to prevent constantly changing levels. When I add manually (which isn't very frequently), the gauge can take a while to read full again. The first time, I almost kept adding oil thinking I hadn't added enough, then it finally went to "full". It's odd though that your reading would vary more than 1/4 quart, that is the gradation of the readings. I add when mine reads 1/4 quart down. Honestly though, I think I only added oil one time, between my 8500 mile changes. I have a 535i, from what I've seen on the forum, 550's seems to use oil a little faster.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 11-18-2012, 10:40 PM
m6pwr m6pwr is offline
Mein Auto: '14 335i M Sport
It sounds like you're doing the measurement when the car is in motion. I think you will get the most accurate and consistent measurements, when you're idling at a standstill, on level ground, with the engine fully warmed up. That's what works for me.
