E36 (1991 - 1999)
Old 11-15-2012, 03:27 PM
ethereal45's Avatar
ethereal45 ethereal45 is offline
Send a message via AIM to ethereal45
Mein Auto: 1998 328i
Help! Key turn kills the entire electrical system - all lights go off, no crank.
Hi all,
About three weeks ago, I left my lights on overnight and killed my battery. The battery was 100% dead -- no cabin lights, no cranking of starter, no clicking, absolutely dead. The battery sat dead for about 2 weeks until I recharged it with a battery charger.
Tonight, I went to start the car. The cabin lights came on and the doors unlocked electronically upon pushing the keyless entry button.
I turned the key, and everything went off -- all cabin lights, etc. No starter cranking/spinning/clicking.
I got out of the car and shut the door and all the cabin and dash lights came back on. The OBC said "Input Time."
I repeated this process about three times....sure enough, the cabin lights came back on each time I got out and shut the doors.
What on earth do I do? This doesn't sound as simple as just replacing the battery....
1998 328i
Koni Sport Suspension
Old 11-15-2012, 03:34 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Im leaning towards it being the battery cause my brothers e46 would click and the lights would flash even though the battery was charged and it was being jump started
once he bought a new battery the car cranked up on the first try without a jump
-Dino
Old 11-15-2012, 03:36 PM
ethereal45's Avatar
This doesn't even click though...when you turn the key it's literally like you flipped an "off" switch for the entire car.
The battery dying last week does seem too coincidental to not be related though -- I never had the battery tested, I just hooked it up to a charger. The charger was on it for about 24 hours and didn't report any problems (although it was a cheap $45 charger), and the car cranked back up with no issues following charging it, and proceeded to start several times after that until this happened.
1998 328i
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Actually, to me it sounds exactly like your battery is pooched. I'd have it tested before you do anything else.
This is precisely what happens when your battery is really, truly dead.
1998 BMW 328is
1966 Pontiac GTO
Old 11-15-2012, 03:38 PM
ethereal45's Avatar
I do have a portable jump starter I can try actually, I'll go hook that up and see what I find.
1998 328i
Old 11-15-2012, 03:40 PM
ethereal45's Avatar
I guess I was getting thrown by the fact that three weeks ago when it was completely dead, I didn't get any cabin lights coming on.
1998 328i
Old 11-15-2012, 03:46 PM
ZeGerman's Avatar
Warm Leatherette
It's because you have a trace amount of charge in the battery now, which is depleted each time you turn the key and attempt to engage the ignition/starting process, but it then recoups slightly after a moment, which then allows the interior lights & locks to function somewhat. When your battery was dead before and nothing worked at all, it was because there was truly nothing in the battery.
I had the exact same scenario in my previous car, and it was a dead battery. Also, fully bringing a car battery to absolute zero is very hard on it, so it's likely that when your battery was dead before, it was the last nail in the coffin regardless of your attempt to recharge it afterward.
1998 BMW 328is
1966 Pontiac GTO
Old 11-15-2012, 03:49 PM
ethereal45's Avatar
That was my theory also, but it sounded too dumb when I thought it up. Now that you say it that does make perfect sense.
Also, the headlights don't come on when I turn the switch....even when the cabin lights are on. I assume that supports dead battery. The orange corners came on though....
1998 328i
Old 11-15-2012, 04:12 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, the headlights pull a lot more juice than the lower wattage bulbs such as the corner and interior lights, so they won't turn on if the battery is as low as yours seems to be. It's the same reason your interior lights work, but the starter doesn't even click.
1998 BMW 328is
1966 Pontiac GTO
Old 11-15-2012, 05:14 PM
BMRfanatic's Avatar
im surprised the hazards didnt start flashing
my car flashed the hazards when my battery was dead and i kept trying to start it
-Dino
Old 11-15-2012, 06:33 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
yeah, sounds like a battery. without a properly charged battery all sorts of goofy things can happen. this also goes for wonky grounds as well....
df
Old 11-15-2012, 07:41 PM
ethereal45's Avatar
Thanks again for the suggestions -- I'm going to see if I can jump it with a portable jump starter and drive it in for a battery test. I'll post updates when I figure it out (hopefully tomorrow).
1998 328i
Old 11-15-2012, 09:13 PM
hornhospital's Avatar
D'oh, You Kids!
Carry the jump box with you. You'll probably need it.
Quotes to live by:
