6 Series
Old 11-19-2012, 02:24 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2012 528i + 2007 650 Vert
Exclamation CAUTION! AE LED replacements
A few weeks ago, I had upgraded my AE's to 5w LED and all was well with no errors. Great color but not very bright. I saw new 25W AE's and decided to give them a try. They looked better but not 5x brighter for sure.
It rained Thursday and Friday but I did not drive the car till Saturday. Sunday after some driving I looked and saw this:
I was not too happy to see moisture in the housing. I removed the AE's and after looking them over I found the issue. These are made differently than the others with a hollow center, most likely to assist in cooling.
I removed the AE's and using some clear tubing, a hair dryer, and about 2 hours, I got the moisture out. I then I used Silicone to seal the openings on the rear of the AE's to keep the moisture out.
The position of the AE's are outside of any protection and therefore exposed to the elements via the normal air flow. This is not a problem with the factory fittings as they are sealed. I'm sure the heat from the LED's caused whatever water that came in contact with it, to vaporize into the headlight housing.
It's all OK now but be cautious on choosing these replacements. The first set of LEDs were sealed but these were not.
07' E64/Black....12' F10/White
Old 11-19-2012, 04:09 PM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
That blows! Nice recovery though.
Definitely beneficial to alert everyone to be careful with aftermarket AE's.
Old 11-21-2012, 07:58 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Bummer
Now I see what you were saying in your PM. Ouch!
So you're going to stick with them and see if you can keep the moisture out?
Hope it works. If not, at least we have a holiday tomorrow
M6 bumpers, skirts & wheels
HUD, Comfort Access
Old 11-21-2012, 11:37 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
I'd be a bit worried using 25W angel eyes... That's a lot of heat to dissipate.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
