wierd noise... and suggestions? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 11-05-2012, 09:27 PM
jarrowood jarrowood is offline
Mein Auto: 97 328 is
Unhappy wierd noise... and suggestions?
got a wierd clicking noise coming from my front drivers side. sound increases with when stepping on the throttle. stop when i let off the gas. almost sounds like the fan is hitting something as it spins but thats not the case. any of you guys have any suggestions as to what i shoulod check next cause for the life of me i can not figure it it out
Old 11-05-2012, 09:37 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Well, you could have failed motor mounts, which would allow the fan to hit the fan shroud under acceleration, but then not hit while decelerating and/or idling. Just to be clear, are you certain it's coming from the engine bay and not one of the front wheels?
1998 BMW 328is
1966 Pontiac GTO
Old 11-05-2012, 10:27 PM
im not sure if its coming from the engine bay or the front drivers side wheel. i didnt think to check the mounts. ill have to do that in the morning. if its not the mounts and its suspension any suggestions on what i should check first
Old 11-05-2012, 10:45 PM
ZeGerman's Avatar
Warm Leatherette
I somewhat doubt it's a suspension related issue, especially since it goes away when you let off the gas. Here's another question: can you make the noise happen if you are parked and just rev the engine somewhat hard while in neutral?
1998 BMW 328is
1966 Pontiac GTO
Old 11-06-2012, 12:16 AM
hornhospital's Avatar
D'oh, You Kids!
If it doesn't do it when revved in neutral, put it in gear and hold the brake to keep from moving, then press down on the accelerator pedal. If it does it then, it's definitely motor mounts.
Quotes to live by:
BMW-CCA #441426
Old 11-06-2012, 10:33 AM
it doesnt do it on idle even when i give it gas but ill go out now and check to see if it does it when its in gear
Old 11-18-2012, 12:45 AM
emh_888 emh_888 is offline
Mein Auto: '08 335i
Mine is making the same noise. Started right after I had new tires installed. Pretty sure it's coming from drivers side front wheel. Any idea what would be causing that noise?
