Well I had 2002 525i rims on my 97 540. I think* all e39 rims are interchangeable, but I am sure I will stand corrected. But if you have the sport packege you need 16" or larger. What size is on your car right now?
![]() Touring the nation, one state at a time |
I know the wheels do.
![]() 01 Anthracite 525i Sport, with 01 E53 3.0, 06 DINAN 4.8iS and 91 Z32TT |
It has to fit because the Front wheel bearing is the same for all 1996-2003 5-series (528i, 530i, 525i, 540i).
Check realoem for BMW PN 31221093427. PS: The exception is M5, which uses different front bearings. |
It's not quite this simple. True hubs are the same, but the specific models use different diameter rotors. 15" wheels will NOT fit 530 & 540.
If '97 uses same diameter rotors as '01 525, then you're OK. Does sticker on "B" pillar say 15" wheels/tires are OK? |
15"s wont fit on any E39 w/sport pkg either.
yes they will fit. the brake rotors on the '97-'00 528i and your 525i are exactly the same so you won't have clearance issues
1999 BMW 540i/6 - Eibach ProKit - E60 SSK - ZHP knob - DJ Autos/FX-Rs/Orion V2s - HID Fogs - M5 front bumper - muffler delete - 19" LM reps ![]() |
I run 15" snows on my '00 528iTM w/sport.
hmm. I was always under the impression the the 15" wheels wont clear the front brakes. Thus I have been searching for 16" winter wheels and have been passing up on 15" wheels. I guess that only applys to the 540? not fitting 15s that is.
That's right, I can't put 540 brakes on my car because I wouldn't be able to use my snow tire rims, maybe eventually I'll get bigger ones. I don't think it has anything to do with sport/non-sport.
2000 528i M-Sport 5speed |
