Old 01-08-2013, 02:47 PM
Mike Swing's Avatar
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
Auto Sense Wiper settings
On the auto sensing wiper settings, which setting is what? If its all the way up, does that mean its faster or more sensitive? Does down mean the opposite? I looked this up in the manual but it doesn't answer my question. It just says to adjust the sensitivity, move the lever up or down. Thanks in advance.
Mike Swing
Old 01-08-2013, 02:56 PM
Yellow Jacket Yellow Jacket is offline
Mein Auto: 2012 550i
I believe up means faster/more sensitive.
Old 01-08-2013, 03:35 PM
Mike Swing's Avatar
Mike Swing
Its raining a lot in Texas right now. I tried up and down and I cant really tell the difference.
Mike Swing
Old 01-08-2013, 04:38 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
I don't think it adjusts the sensitivity. From my experience when the rain sensing feature fails, the system defaults to the traditional mode. (This has happened to me). Across country trip 2 years ago, during the trip one day I pressed the rain sense button and got nothing. Flipped the stalk up once and it was going at an intermittent pace. Flipped it again and it was steady slow. Flipped it up again and nothing else (steady fast is only for high speed which makes me think its wheel speed sensitive also).
The knurled switch did seem to adjust the intermittent swipes on manual mode ONLY after the rain sense failed. I did fix it under warranty at BMW of San Diego. I haven't found anything similar to this scenario anywhere, and I have certainly looked. I've read countless manuals and couldn't find an answer about the knurled switch. I will say however that if the rain sense feature fails the car DOES default to a traditional mode which I've found to be great or I would have been stuck in Tennessee a few extra hours.
Old 01-08-2013, 04:56 PM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
I've noticed with mine that if the thumb switch is all the way down, the wipers activate less often than if the the switch is up.
Having said that, I am extremely disappointed in this feature, particularly since it replaces (rather than supplements) a true intermittent wiper. I noticed that a previous poster stated that when his system was not operational, the default was intermittent. If the frequency of the wiper activation was adjustable using the thumb switch, I'd be much happier than either relying on the sensor, or having the wipers on all of the time. What I've found is when there is only mist in the air, like when the road is wet, but it isn't raining, so the only water is coming from the tires of the cars around me, the wipers go off constantly. The opposite occurs if the rain drops are very big, but sporadic; the wiper never goes off then. Personally, this is one of those features that I could do without.
Keith
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 01-08-2013, 06:28 PM
rube rube is offline
Mein Auto: 535i xDrive
Keith
I agree with all of that, i was just thinking the same thing during the last rain we had around here. I would prefer to have a true intermittent wiper as well.
Old 01-08-2013, 06:38 PM
DAI's Avatar
DAI DAI is offline
Gap Filler for a M6 GC?!?
Mein Auto: '10 550i M-Sport
[QUOTE=Campfamily;7299269]I've noticed with mine that if the thumb switch is all the way down, the wipers activate less often than if the the switch is up.
/QUOTE]
+1
However, mine actually work pretty good. When I get into my truck without this feature, I do miss it.
Old 01-08-2013, 08:03 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
It's a better system than the auto-sensing wipers on our Mazda - if it 'thinks' it's raining hard enough, it switches to high speed and won't shut off, even though an intermittent setting would work. Can't defeat it either. At least the BMW mode can be defeated (green light off, works like traditional intermittent (at least mine does)).
Old 01-08-2013, 11:21 PM
Mike Swing's Avatar
Mike Swing
Just drove through more rain and this is what I've come up with so far. It is more frequent when the thumb switch is in the upper position. Doesn't work very well with mist until it builds up. Last, I found out that if the car is not moving, it won't wipe much at all. With that conclusion, I also noticed that the faster the car is moving the more it wipes (unless its a fine mist of water until it builds up). It worked well when the rain got thicker and the rain drops were bigger. I just wish it would work better on fine rain like mist and that it would wipe sooner at lower speeds. I'm still on the fence if I like this feature or not.
Mike Swing
Old 01-09-2013, 06:30 AM
eddieliu eddieliu is offline
Mein Auto: E60 525i
I have the same situation here in Taiwan. The auto sensor doesn't work very well with mist and small rain drops.
In heavy rain, it wipes with higher speed when drive fast and lower speed when drive slow/idle.
Old 01-09-2013, 06:33 AM
Mac Hadley Mac Hadley is offline
Nac
Mein Auto: 535XI, 328I
It makes sense to me that the wiper speeds increase when one drives faster, as you contact a greater volume of rain...the converse would be true also.
Old 01-09-2013, 07:38 AM
Campfamily's Avatar
Didn't know that. It's supposed to rain tomorrow here in Southern California (we're getting 1/4 inch of rain, so we're on STORMWATCH, according to our local news!! ), so I'll try that and see if it works that way on my car.
Keith
Old 01-09-2013, 07:57 AM
colin007 colin007 is offline
Mein Auto: 2007 530i
mine does not do intermittent at all, unless it is on rain sensor. i HATE that...my only options are 1) rain sensor (which i cannot control), 2) regular speed (no pause) and 3) full blast hyper speed. there is no option if i want it to wipe consistently every 3 seconds (or whatever). seriously BMW, you can put a rain sensor in the car but you cant give me a regular intermittent wiper?
Old 01-09-2013, 11:52 AM
Campfamily's Avatar
^^^^^^^ Couldn't have said it better myself ^^^^^^^
Old 01-09-2013, 02:57 PM
Gilgorm Gilgorm is offline
Mein Auto: 2012 535i X-drive
Don't forget that the wipers go down one speed when the car is stopped. Rain sensor slows down to ALMOST off when car is stopped.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
Old 01-09-2013, 03:34 PM
patrick_y patrick_y is offline
Mein Auto: 2004 BMW 545iA
My biggest complaint about driving in the rain in this BMW is the windshield. The Mercedes-Benz vehicles I drive and I've driven in the past seem to have a coating on the windshield that makes the rain bead up and leave the windshield faster. The BMW windshield is probably missing this coating. Overall, driving the BMW in the rain is much less enjoyable than driving a Mercedes-Benz vehicle.
The rain sensor in my BMW seems to be okay, not sensitive enough in the most sensitive setting sometimes. The water forms a flat "splat" on the windshield when on the windshield of the Mercedes-Benz it would form a bead where you could clearly see around it.
I recently applied a layer of RAIN-X spray, a liquid from a spray bottle that you wipe on that supposedly gives the water some sort of electric charge. It's a temporary solution (I imagine it wears off eventually), but I hope this helps. It will rain in a few days and I'll see if I notice any improvement.
This is my first BMW and coming from the Mercedes-Benz camp, I'm still evaluating the differences between the two fantastic cars. But the BMW 545i really has a terrible windshield for not having this aforementioned coating. I even think the Lexus vehicles I've driven have the aforementioned coating. I see no viable excuse for BMW not having this coating on their vehicles.
Old 01-09-2013, 06:49 PM
Campfamily's Avatar
There is something on your windshield that is causing this to happen. Rain drops on my windshield bead up and are swept away by the wind. In fact, on the freeway, particularly at night, I don't even need the wipers on. I strongly suggest you do a deep clean on your windshield. I've heard some say that using a clay bar on the windshield is a good idea, although I've never tried it.
Keith
Old 01-09-2013, 07:02 PM
Keith
Hmm, I have a clay bar, I can try that.
Windshield has definitely been very thoroughly cleaned before, although not with a clay bar.
Thanks for the suggestion.
Old 01-09-2013, 11:24 PM
Mike Swing's Avatar
Mike Swing
Griots makes a clay bar just for glass.
http://www.griotsgarage.com/product/...ortby=ourPicks
Mike Swing
Old 01-10-2013, 12:25 AM
Thanks Mike! I just clayed the entire car on Sunday, but didn't think to clay the glass. I didn't even know that one was supposed to use a clay bar on glass.
I'm really starting to think that maybe the 2004 model years didn't have the special treatment on the windshield. But I'll give my normal clay bar a try on the windshield and see if the situation improves and I'll get the Griots clay bar the next time I'm placing an order.
Thanks again!
Old 01-10-2013, 12:37 AM
Keith
Indeed, water drops bead up and are swept by the wind as the vehicle's speed increases.
I'm also wondering it may be possible that I have a different windshield. Two things;
1. Maybe 2004 models didn't have the windshield with water repellant coating yet. This again would be highly disappointing because I've had earlier Mercedes-Benz vehicles that have had this coating.
2. My vehicle has the Head Up Display. I don't think that the windshield itself is different from other E60s without HUD, but it is possible that that there is a special coating on the windshield (inside or outside) that negates the water repellant coating normally present? The BMW Owners Manual states that the windshield is a unique windshield, but not necessarily unique within E60 windshields, it mentions more about the curvature and a film. Perhaps this film negates the water repellant coating?
BMW Manual Quoted:
Special windshield
The windshield is part of the system. The shape of the windshield complies with the require- ments of the Head-Up Display to enable a pre- cise display. A film in the windshield prevents the double images from being displayed. Windshield replacement should be carried out by a BMW center or a workshop that works
according to BMW repair procedures with cor- respondingly trained personnel.
So Keith, does your 550i have the heads up display?
Thanks again!
Old 01-10-2013, 07:49 AM
Campfamily's Avatar
Thanks again!
No, it does not. I really wish it did, though. Maybe that is the difference.
