E46 (1999 - 2006)
Old 11-16-2012, 08:02 AM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
Body Twisting
This may be wierd, or i may be looking at this matter a bit too much, when when i am turning and hit a bump, the front of my car feels fine, but the back sort of steps out a bit. almost like the car is twisting.. in a straight line it feels fine. i highly doubt that it i something wrong with the chassis, but could it be something with the suspension? the car has done about 4 drifts in its lifetime so could that have done something? Help a worried e46er!
Old 11-16-2012, 09:05 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
It's called bump steer or roll steer.
You might need to have your alignment checked, or perhaps there are worn rear trailing arm bushings, or some other suspension anomaly. If you have 80k miles or more, your shocks and struts may be in need of replacement. Your front control arms and/or bushings may be worn too.
How's your tire pressure? Too high and the tire may be jumping over bumps rather than gliding over them.
Jeff R.
Old 11-16-2012, 09:35 AM
Fast Bob's Avatar
Keeping it surreal
Jeff is right on the money....when all those rubber bushings get worn, everything gets sloppy and you lose torsional stiffness.
The road goes ever onward....
(R.I.P. Jever)
Old 11-16-2012, 10:16 AM
j_schroeder's Avatar
j_schroeder j_schroeder is offline
Mein Auto: 330ci
Due to michigan weather my subframe bushings are toast and i get the same thing.
2001 330CI
Old 11-16-2012, 11:27 AM
bmw330ci04's Avatar
Can you fix the subframe bushings?
Old 11-17-2012, 08:48 AM
Mein Auto: 330ci
Yea they can be replaced.
2001 330CI
Old 11-17-2012, 10:36 AM
bmw330ci04's Avatar
Thanks for all the input fellas. I googled subframe bushings and it looks like a tough DIY, but it can be done. As far as suspension bushings go, pretty common stuff, I'm just going to wait until winter is over to do it all
