Old 11-16-2012, 09:20 PM
SmartSolution's Avatar
SmartSolution SmartSolution is offline
Mein Auto: BMW E39
Broken metal tab/piece while replacing vcg
Ok so good news is I have successfully installed a new valve cover gasket and ngk spark plugs today. While removing wires out of the way I accidentally broke off a piece of the metal fixture shown in the pics. It holds the wires in the area marked with red. What part number is it and what is it called? I would like to replace it. I looked on realoem but could not find it. it seems to be attached to the valve cover and a the remaining piece is still in a slot in that corner.
Thank you.
BM109R
ID:	349815   Click image for larger version
Name:	broken metal piece.jpg
Old 11-17-2012, 05:05 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i, 2005 X3
I did the same thing a couple of years ago. As far as I could tell, you had to replace the entire Valve Cover as the metal piece is not available separately. I pretty much have ignored it with no ill effects.
Old 11-17-2012, 06:00 AM
Fudman's Avatar
Fudman Fudman is offline
I believe that piece of metal is a heat shield to protect the wiring from the exhaust manifold heat. You could wrap the wires in tin foil (shiney side out) or jury rig some roof flashing to replace the function of that piece.
