E46 (1999 - 2006)
Old 11-17-2012, 11:04 AM
cflood330ci cflood330ci is offline
Mein Auto: 2002 bmw 330ci
2002 bmw 330ci fuel pump
hi im trying to see if anyone could tell me why my 2002 bmw 330ci fuel pump wont come on i replaced the whole pump and the filter and the relay and everything else works but the pump wont come on what should i do
Old 11-17-2012, 12:36 PM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
You checked all connectors and fuses
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 11-17-2012, 12:42 PM
Yes the fuse and the relay are good
Old 11-17-2012, 12:44 PM
It will turn over and everything but will not start and the fuel pump wont come on so i have no fuel pressure
Old 11-17-2012, 01:25 PM
shadow 2 shadow 2 is offline
Mein Auto: 2011 335ix
Is the pump getting current?
Old 11-17-2012, 02:02 PM
No no current idk what to do
Old 11-17-2012, 02:24 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Did you check the relay in the compartment under the hood?
Sent from my PC36100 using Bimmer App
Old 11-17-2012, 03:07 PM
Yes i have
Old 11-17-2012, 05:22 PM
The car drove fine befor i got this problem all wen my crankshaft position sensor went out and wenever i changed it is when it started doing this the fuel pump wont come on so i replaced it and the filter and the relay and it still wont come on
Old 11-18-2012, 12:11 AM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Need to go back to basics. Check to make sure the connector at the pump is fully seated?
If OK there, need to check for voltage back at the pump?
If voltage, perhaps a bad new pump. If no voltage, have to trace back the circuit.
Let us know what you find when you do these tests.
Intermittent electrical problems are the worst to track down.
Old 11-18-2012, 02:47 PM
I got the car to start i drove it to town and back home but now it wont start again
Old 11-19-2012, 04:38 AM
wdgiles's Avatar
wdgiles wdgiles is offline
You can call me Bill
Mein Auto: 2001 325i
Mine has been doing the same thing this weekend, won't start, wait a day, then it works with no explanation. I was able to start it briefly with some engine start into the intake, but now it doesn't work again. Don't worry you're not alone.
I have '01 325, but same basic setup, I've confirmed I have voltage at the pump but no response from the pump itself, so you're one step ahead of me. I plan to get the replacement installed today.
*Current* -- 2008 335i Convertible
*Retired* -- 2001 325i - https://picasaweb.google.com/bgiles/2001325i#
Rockwall, Texas
