Old 11-17-2012, 10:32 AM
rubberducky203's Avatar
rubberducky203 rubberducky203 is offline
Mein Auto: e39 525i, F10 535xi
Exclamation Engine screech at start up
The problem started yesterday morning as when I started it up I got this horrible screech from the front of the engine any help is greatly appreciated.
"So what does that M/S stand for?"
"It stands for manual"
"And the S?"
"...Swagger"
2003 525i
2011 535xi
Old 11-17-2012, 10:53 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Sounds like a bad bearing in an idler, or one of the accessories, or a worn-out fan clutch. Don't drive it until it's fixed. The bearing could seize and cause more damage.
Old 11-17-2012, 11:06 AM
I'm replacing the fan clutch today to see if thats it
"And the S?"
"...Swagger"
2003 525i
2011 535xi
Old 11-17-2012, 12:45 PM
Be sure to examine the idler wheels and accessory bearings by spinning them, looking for noise.
Old 11-17-2012, 03:02 PM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '97 528i
i doubt its the fan clutch.suspect the water pump.
Fuelly
Old 11-17-2012, 03:21 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Is it Safe to Dance?
Mein Auto: 2001 540i/6
take the belt off and see how all the pulleys turn.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 11-19-2012, 12:36 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Check this out:
- How to diagnose noises coming from the drive belt system (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 11-19-2012, 03:24 PM
Pulley b in the attached picture is making a odd noise
Also how do I get the pulley right above it off as its in the way of getting the noisy pulley off.
Here's a vid too.
"And the S?"
"...Swagger"
2003 525i
2011 535xi
