Old 11-17-2012, 11:46 AM
simplyoriginal simplyoriginal is offline
Mein Auto: 540i
miss fire
Hi Everyone ... Can a weak battery throw misfire codes in a 2000 540i ?White smoke is seen too early in morning but sometimes only..one it didnt start n when i got a jump it smoked.. one mechanic say it can especially early in the morning ..Any advice on this ? another said coolant leak, another said valve seals, car did a full tune up all dealer parts in june .. this only happens once in a while
Old 11-17-2012, 12:11 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Waek battery maybe--my first bet would be Vacuum leaks--how the fuel mileage and engines power doing out on the road--if both are down--bet you have a vac leak somewhere
Old 11-18-2012, 02:25 PM
Mein Auto: 540i
thanks..the power not too bad but, today i went under n checked the catalytic converters , the left rear driver side sounds bad inside when i tap it ...can that cause enough back pressure to cause that...it did throw a calalitic code too ,since i have all brand new bosch sensors too...it was at bmw dealer few month back for complete diagnostics and they found a vacume line cracked after doing a smoked test it was replaced tho...can it be a new one?
Old 11-18-2012, 05:03 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Clogged cats can cause misfires, but they are generally random multiple misfires on the bank with the clogged cat.
Old 11-19-2012, 07:13 PM
Mein Auto: 540i
Ok Thanks allot I think that is exactly what's going on ....the computer did say random misfire and today no smoke and very little engine shake ..its crazy...i'm gonna change the cheapest cat in the failed bank first ...the one thats broken inside isbank 2 rear ( driver side) crossing my fingers it solves the problem and i don't need to change the front one
Old 11-19-2012, 07:26 PM
If it has power at all and drives OK out on the road--it isn't a cat that's the problem--a cat will let the car go only so fast and then feel like the car is surging--check out for vac leaks first--they can cause the very problem you experiencing
Old 11-21-2012, 07:17 PM
Mein Auto: 540i
ok thanks ...will do
Old 11-21-2012, 09:12 PM
bluebee's Avatar
bluebee bluebee is online now
Seek to understand,^Value
For misfires, look here ...
- How to diagnose a BMW E39 engine misfire (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 11-25-2012, 10:31 AM
Mein Auto: 540i
Found a leak at the throttle body gasket ,,thanks guys .. will change it and let you know how she runs
