Old 11-17-2012, 12:57 PM
Casselx Casselx is offline
Mein Auto: 2006 BMW x3, 3.0i
Exclamation GPS Navigation stopped working
My GPS Navigation stopped flipping up and also stopped showing the screen, Its not necessarily a vital organ for my 2006 BMW x3, but its a pretty important one considering it also hosts the radio and everything else. I'm not sure if its just a wire being undone in the back or if its the actual motor in the Navigation system. We checked the fuses which are fine. Is there a way to remove the GPS System so I can check the wiring to it? Any advice is very much appreciated.
Old 11-17-2012, 06:21 PM
x3brian x3brian is online now
Mein Auto: X3
Check your fuses. I had a similar problem and I believe it was fuse 42 but there are 3 or 4 other fuses tied to the radio and screen.
Old 11-18-2012, 07:53 AM
Ok, i'll check fuse 42, none of them seem to have been burnt out, but It doesn't hurt to double check.
Old 11-18-2012, 06:42 PM
slemmer slemmer is offline
Mein Auto: '04 645cic '00 740i Sport
If the fuses appear to be ok you then need to check the connector to the unit to verify it too has power. Then you'll have a better idea if it's the unit or somewhere back towards the fuse block.
