E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
1.9l exhaust recomendations.
Now before i have people yelling at me to use the custom search bar, i just want to let you guys know that i have used it and have not found a direct answer. I have a 96 1.9l and im just looking for an exhaust that will give me a more appealing sound than the stock one. I have not been able to find many videos online so i decided to come here to look for some help. Do you guys have any recommendations?
Ansa. I have it on mine.
1996 Z3 (M44) |
you could check with some exhaust shops just for the heck of it. might be way cheaper
Alright ill check it out. And what rims do you have on your car? They look really good.
The attraction was that it was bolt on. Current Supersprints are cheaper but apparently come with a separate front connector pipe carrying the flange, that must be welded onto the end of the muffler's pipe. I am pleased and fascinated by the Supersprint's complex and varied sound. There is a rasp when started and blipped, and when releasing the clutch on take off. Underway there is a hoarse, windy, muted mutter, not very audible except under heavy throttle and when going under a bridge etc. I have had aftermarket mufflers on two BMWs and a Rabbit and a Scion, and this is the best one yet. The sound is perfect. A shop installed it, and the muffler did not hang centered in the bumper opening -- it touched the right side. I took off the two rubber muffler hangers and the muffler did not shift. So I cut up an extra rubber hanger to make a rubber spacer washer which I installed on the inside of the right rear rubber hanger, and that pushed the muffler to the right, centering it perfectly. |
I swear by supersprint, completely drone free and plenty loud. Don't worry never figured out the search bar myself
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson Supercharged |
| Bookmarks |
| Tags |
| 1.9l engine, exhaust, z3 |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
