Old 01-13-2012, 03:48 PM
brianrparker brianrparker is offline
Mein Auto: 1997 BMW z3
Z3 1.9 engine oil
97 z3 1.9L
Im planning on changing my oil on the car. Im reading that it takes 4.7Q of 15W-40 and that just sounds wrong to me. what do you guys think? and what do you guys use?
Old 01-13-2012, 04:40 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
5w30
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
ok yeah i called bmw they told me 5w30 also.
Old 01-13-2012, 08:51 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
When the 1.9s were new they came with 15w-40 non synthetic oil. BMW was using Valvoline then. They later switched to Castrol 5-30 synthetic, I think in 1999. I have been using Royal Purple 15w-40 for the last 150k miles. I do live in Texas so I use it year around, you might want a thinner weight if you drive in the cold. But what you are reading is correct, although you will use 5 qts to get to the full line.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 01-13-2012, 10:48 PM
Should i got 5w-30 synthetic, part or non synthetic? I have always been told it does not matter.
Old 01-14-2012, 04:45 AM
dougmcintyre dougmcintyre is online now
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
If you want your engine to last as long as possible, use synthetic. Otherwise, doesn't matter.
Old 01-21-2012, 07:04 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Full Synthetic.
BMW (Castrol), Castrol, or Mobil 1 are my choices.
0W-40, 5W-30, even 10W-30 would be fine.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 11-17-2012, 08:51 AM
mlhilla mlhilla is offline
Mein Auto: 1998 z3 1.9l
My expirience with 1998 Z3 1.9L is that Pentosin 5w30 runs cleaner without consumption. Only has 58k miles; but tried Mobile 1 twice. Each time I consumed 1 liter per 1000 miles with an increase in upper valve / cover varnish. Each time I switched back to Pento the consumption stopped, and the deposits went away. FL. driver, mixed highway, slow beach cruzin.. Tried Pento as recommended by German / Turkish shop owner / tech in Tampa....he was right......at least for my Z.
Old 11-17-2012, 04:53 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 1996 Z3 1.9L M44
Hit walmart - they often have sales on Mobil 1 5w/30.
1996 Z3 (M44)
Old 11-17-2012, 06:11 PM
mnguyen84 mnguyen84 is offline
Mein Auto: 96 z3 5spd
i just did an oil change in my 96 1.9L and it was 5.3-5.5qt of oil.
Old 11-21-2012, 05:40 PM
vintage42's Avatar
BMW CCA 1405
97 z3 1.9L... Im planning on changing my oil on the car. Im reading that it takes 4.7Q of 15W-40 and that just sounds wrong to me. what do you guys think? and what do you guys use?
I just bought the same car from a BMW dealer and had them change the oil. They put in BMW synthetic 15W-40, which is what they said it takes. I really don't think it matters much, especially the way I drive, and plan to do the next oil change myself at 5K miles out of the stock of synthetic 5W-30 that I use for our other cars.
Old 11-21-2012, 07:56 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Send a message via Skype™ to Dave 330i
Mein Auto:
5-30 Mobil 1 every 5K miles, but now every 10K miles. 144K miles on engine. When I had the valve gaskets replaced, the BMW dealer tech said that's the cleanest engine he has seen. 5 qts of Mobil 1 at Walmart for about $26, like one post said sometimes they are on sale.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 11-22-2012, 04:19 AM
Pinecone's Avatar
M Mad
AFAIK BMW doesn't make a 15W-40 synthetic. Their current oil for almost every BMW is a full synthetic 5W-30. The oil caps of the older cars say 15W-40, but that was a conventional oil.
I use the BMW 5W-30 in our Roadster, basically because with the BMW CCA discount, it is one of the cheapest full synthetics out there. I use Mobil 1 in two of our other cars (M3 LTW and Jeep Grand Cherokee). Castrol TWS 10W-60 in the E46 M3 because that is what is speced.
Most of our vehicles get the oil changed every year, as the mileage is not enough to trigger the change.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 11-22-2012, 05:15 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by Pinecone View Post
AFAIK BMW doesn't make a 15W-40 synthetic... The oil caps of the older cars say 15W-40, but that was a conventional oil...
I see that is so.
High Power 07 51 0 017 868 is what appears on the dealer invoice for my oil change. That would be:
"Motor oil High Power SAE 15W-40
Part number: 07 51 0 017 868"
http://bmwfans***91;/img] ******** LINK B...g/07510017868/
Anyway, I just googled High Power 07 51 0 017 868 to see page.
And I do see from a bulletin that it is mineral oil, not synthetic:
"... SAE 5W30 BMW High Performance Synthetic Engine Oil is formulated with
advanced additive technology to meet BMW specifications required in line with our
extended service intervals. As such this is the only oil to be used in conjunction with
the BMW reimbursed maintenance program.
07 51 0 017 866 5W30 Synthetic
07 51 0 017 868 15W40 Mineral..."
BMW NA Bulletin 11 01 01 dated 03/01
My 1997 1.9L oil cap does not say anything. The Owners Manual does say 15W-40 above 15ºF, and does not mention synthetic.
Old 11-22-2012, 08:25 PM
i dont think anyone makes 15w-40 full syn. you can find 5w-40 full syn, which flows better when it's cold. In theory and lab testing, synethic oil is better than conventional. It maintains its grade longer, at higher temp, it evaporates less, and flows better. However, in the real world unless your car is designed for syn oil, it doesn't mean that your car encounters extreme conditions where it can take advantage of these benefits. thus, no one can truly make the claim that synthetic is "better" for your car.
overall, 15w-40 is a good grade, and you have lots of options, such as Shell Rotella, Chevron Delo, Mobil Delvac....etc
Old 11-23-2012, 05:36 AM
Pinecone's Avatar
M Mad
MObil 1 makes a 15W-50 synthetic, or at least used to.
Yep, they still do. http://www.mobiloil.com/USA-English/..._1_15W-50.aspx
Full synthetic oils were not that commonly used when the early Z3s were produced.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 11-25-2012, 09:01 PM
seth1993's Avatar
seth1993 seth1993 is offline
Mein Auto: BMW Z3
I have 5 courts of that junk in my garage. Thick as syrup.
I use Mobile 10w-30 year round in my 1.9
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
Supercharged
