E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Adaptive headlight not working
I just replaced my xenon bulb on both headlights and now the adaptive headlights are not working.
I am not getting any malfunction messages or anything but the light where I switch on my headlights on the inside is blinking. Any ideas? Thanks. Sent from my MB886 using Bimmer App |
If you do a seach you'll find that yes it is a warning about the adaptive lights.
Sport, Premium and Cold Weather Packages. |
But why!!
If you don't get any message, check your switch command, is the little LED green flashing or fixed? and your main bulb headlamp side right is in position right (looking forward) or turned left or turned right?
Sorry if I don't explain correct it. |
[QUOTE=Simonnim916;7200556]I just replaced my xenon bulb on both headlights and now the adaptive headlights are not working.
I am not getting any malfunction messages or anything but the light where I switch on my headlights on the inside is blinking. Any ideas? Is it the OEM bulb or after market?
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |Front/Rear Cameras | Escort 9500ix | Performance-Cobb Stg2+FMIC ST Agg | Injen Intake | BMS OCC | ER anodized FMIC |AR DP Catted |TIAL Q BOV | ER Charge pipe | Spacers (F 12mm/ R 18mm) Cosmetic-32w Cree LED AE | Xenon HID Fog Bulbs | M5 trunk & Roof spoiler rear | XENON white Emblem LED BG Light | LED Side Marker | M5 bumper | Hamann LP | License & Interior LED lights| Tinted glass | |
This morning I had pulled out the headlights and put them back in. The light doesn't seem to be flashing anymore...I put a sock on the light sensor. I'll update tonight if it's working. Sent from my MB886 using Bimmer App |
[QUOTE=Shahul_BMW;7201465]
Ok so I just removed the headlight and put it back on. It's working now lol, no idea why but 2 major things I did was fully push up the clip on the passenger side light on the big plug and driver side I just loosened the screws and let the lights move back to its original spot.
I moved the headlight a little to better fit my aftermarket m5 tech bumper. Nonetheless it works. Thanks for all the help guys. Sent from my MB886 using Bimmer App |
Congratulation, at the first I thought the headlight had lost the bend adaptive function (like in my car), but only it were a bad connection, an easy solution...
Thanks =)
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
