Old 11-17-2012, 08:26 PM
Bluedevil1 Bluedevil1 is offline
Mein Auto: 97 540iA
M60M44 Swap
I have a 97 non vanos 540i and Im excited bc today I have just found some clean m60 heads complete fairly cheap. I know there are a couple guys running this set up in e30's so I searched for parts. I have heads,timing covers.
I believe that bmwmech1 has this set up and from reading the posts on e30 tech looks like the CR will be 10.94:1 and I have also read that there is a guy out there that is running an m60 with larger injectors for e85 and milled his heads 1.6mm to put him at 12.5:1 and I want to be around 11.8-12 . how much would need to be milled off to get to where I want to be? I'm horrible at math
I will get a tune and injectors before the swap.
Old 11-18-2012, 05:34 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Is it Safe to Dance?
Mein Auto: 2001 540i/6
Are m60 heads better?
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
coming soon:
Bc coils
Jb lwfw
Old 11-18-2012, 09:50 AM
Mein Auto: 97 540iA
M60 heads are identical other than smaller chambers bc they had a smaller bore which adds more compression
They also have an extra set of teeth for the timing chain on the cams, Hotter or lumpier cams
Old 11-18-2012, 05:42 PM
shocwav3 shocwav3 is offline
Mein Auto: 1998 540i
Wiki lists the M60 as having 4+ horsepower over the M62? I am curious if that is true.
Any documentation on the gains associated with the compression bump?
Old 11-18-2012, 07:20 PM
Mein Auto: 97 540iA
I cant see the m60 having any hp over the m62
No documentation as of yet but i'd like to do a before and after if I put the heads on before the stroker.
Old 11-18-2012, 08:00 PM
Topaz540i's Avatar
What is stock m62 compressiom?
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
coming soon:
Bc coils
Jb lwfw
Old 11-18-2012, 08:09 PM
Mein Auto: 97 540iA
10.0:1 and it should end up at 10.94 according to someone elses math
Old 11-18-2012, 09:02 PM
Should be a difference you can feel. Keep us posted if it comes to fruition.
Old 11-18-2012, 09:10 PM
Mein Auto: 97 540iA
Yes I'd be happy with 40 bhp
12:1, 540i, hp, m60, m62, swap
