Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - Current)
The 5 Series Gran Turismo -- now available in the USA as a 535i, 550i and 550i xDrive model.
Old 11-18-2012, 02:08 AM
PPDJ PPDJ is offline
Mein Auto: Ferrari 360, MB E350
Wheel offset for 550 GT
I have a set of 20" HRE
Front - 9.5" ET28 w/NITTO INVO 255
Rear - 11" ET 32 w/NITTO INVO 285
Just wondering if they will fit on 550 GT with sport package? Car comes with 20" factory rims. Because I have not purchased car yet so I'd like to find out if these wheels will fit or what spec of spacers I will need.
PPDJ
Old 11-18-2012, 02:46 PM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT
To fit any car, the bolt pattern and size, offset, width, and diameter must all be within certain specifications. Then, the wheel must be capable of mounting the TPMS (at least in some places, you won't pass if that is not present). You may already know that, but it's lots more than just the offset that matters if it will fit. First, the bolt pattern is: 5-120, and the rest of the stuff depends very much on the specific wheel as to whether it will fit. It must be able to be bolted on, fit over the calipers, and not put excessive stress on the bearings, and to pass inspection most places, the tire edge at least on part of the wheel must be within the fenderwell when going straight ahead to keep from flinging debris out behind and becoming a hazard for those following. The tire/wheel package chosen must also be within a small variation of the factory package for the gearing, speedometer, and odometer readings to be correct.
If you're lucky, someone here will know, but you might want to check with the wheel manufacturer to see if they will fit.
Old 11-18-2012, 10:28 PM
razorback razorback is offline
Mein Auto: GT 530d
the specs of the Original BMW 20" rims is :
front: 8.5 J x 20 ET 25 (245/40 R20 99Y)
rear: 10 J x 20 ET 41 (275/35 R 20 102Y)
and somewhere in the specs there is a minimum weight rating per wheel but unfortunately I don't know where to find this.
R
edit: at least I found something:
the weight rating per wheel is expressed in the Load Index of the tyres
so for the fronts: 99 means 750 kg, for the rears 102 means 850 kg and Y is the max Speed index of the tyre (Y = up to 300 Km/h)
R
Old 11-19-2012, 12:17 PM
Most wheels would have no problems with the max load...but, not all will fit, which I understand is the orginal question. IWO, two different wheels in the same size from two different manufacturers to fit a vehicle properly need everything to line up - the bolt pattern, the offsets, and the actual inner shaping (often determined by the machining) of the wheel so it can clear the calipers and any other suspension and frame components when turning or even straight ahead. Having the centerline of the wheel too far in or out from the design puts extra loads on the bearings, and if too far out, slings pebbles and other debris onto the car and those behind which can be quite expensive and dangerous.
I do not know what those numbers are, BMW probably won't tell you, and your best bet is to talk to the aftermarket supplier and see if they've confirmed it will fit.
HTML code is Off
