Old 11-18-2012, 05:51 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
How hard does your A/C blow?
I'm trying to figure out if I have a weak blower motor. I had a Mercedes before I bought my 7 and the a/c blew out like a hurricane on the max setting, this car is weak in comparison. How hard should the a/c blow?
Old 11-18-2012, 06:24 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
Before you do anything, check cabin air filters...and the housing - maybe clogged up with dirt or debris
Old 11-18-2012, 08:58 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
My AC sucked untill I registered the battery, works great now
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 11-20-2012, 06:28 AM
My filters are pretty dirty which could be one of the problems. They will be replaced soon
Old 11-20-2012, 06:29 AM
My battery is registered. And I also checked blower output through inpa. I'm leaning more towards a weak blower motor.
Old 07-16-2013, 01:08 PM
djeargazm djeargazm is offline
DJeargazm
Mein Auto: 2010 750i x-drive m-sport
Did you every figure this out?
My blower runs very slowly too but every once in a while, it will blow you out of the seat for a while. There doesn't seem to be any rime or reason . Max AC does nothing unless the car is in the mood to make the blower spin fast which is only about 2% of the time.
2010 BMW 750i M sport
Jet Black, Black Nappa Leather, Ash Grain Wood Trim
Fully Loaded
Previous: 2003 BMW 745Li Sterling Gray Metallic
Old 07-16-2013, 04:09 PM
No I never did figure it out. I'm honestly not even sure how hard the ac is supposed to blow
Old 07-16-2013, 11:32 PM
Jsedita74 Jsedita74 is offline
Mein Auto: 2006 750LI
my AC cranks on its max setting... And Im in NYC where its been almost 100 last wk or so
Old 07-17-2013, 02:47 PM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
+1...there must be something that limits the blower current draw because the same thing happened to me when I replaced the battery before it was registered.
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 07-17-2013, 07:33 PM
It's along the lines of when the battery voltage is low on your car. Until the battery is charged its in a "reduced power mode" to conserve energy and thus the blower will only go to about half speed. Same with an unregistered battery
Old 07-17-2013, 07:35 PM
Not mine. It feels like half speed of any other car I get in.
Old 07-18-2013, 03:49 PM
mws mws is offline
Mein Auto: 760Li, F250 V10, Ex 7.3L
My 2003 760Li is a bit picky, and I have even replaced the AC pump (for a different reason). In any case, I find that the A/C does not really bump into freezing my ears off, unless I get into the car and press MAX for awhile. Then I press Auto to get the climate control to try to regulate things and it's usually so cold I have to back the climate control temp way off.
I even have situations where it says 79* F outside, and I have climate control set to Auto and 75* and it's fricking just freezing my ears off. I keep bumping it to 76, then 77, then 78, etc, to get it to back off and not freeze me.
Many times I get into the car if it's hot as hell outside and I try to use climate control, only (I don;t use MAX). I figure it MUST know it;s hot and it should blast me. It almost never does. Even set it fairly low, like say 68*F if it's 100*F outside. It does almost nothing, I might even get slightly warm air out the ducts. Then I hit MAX and it freeze me to death again, as above.
I have come to accept it.
