Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 11-18-2012, 06:35 PM
JCG1956 JCG1956 is offline
Mein Auto: Lexus
Dynamic Damping Control
I do not yet own a BMW, but I am seriously considering a purchase of a 2013 750i all wheel drive. Does anyone know if the car keeps the setting on the last-used setting on the dynamic damping control (comfort, normal, sport or sport+) so that when the car is turned off and then back on again, that same setting is still in place, or does the driver have to re-manually set that setting again after the car ignition is turned back on? Thank you.
Old 11-18-2012, 09:20 PM
itschase itschase is offline
Mein Auto: F06
As of now it defaults every time you turn off the car, so you'll have to select your desired setting (eg: Sport) every time you start the car. A lot of people are working on custom coding to change that - but no luck so far.
Old 11-19-2012, 01:25 AM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2013 750i
The exception is Comfort+, it will stay after you turn your car back on.
I tried to see if Alex could code it while he was coding other things but he hasn't found/figured that one out yet. We're not the only people that want that coded.
2013 BMW 750 - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate, Vinyl Black Gloss Roof Wrap.
Old 11-19-2012, 10:48 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
Well after a while it gets into your ritual. Touch door(comfort access), get in, nearly close door(soft close automatic), put on seat belt, start engine, put in sport, press auto hold(no need to release parking brake), put in reverse.
