E36 (1991 - 1999)
Old 11-18-2012, 07:48 PM
Phensteel Phensteel is offline
Mein Auto: 318i E36 1994
E36 staggered wheels, negative affects over time?
I have had to replace two wheels, so i purchased some 215/60's 15" for the back and 195/60 15" for the front to give it a staggered effect ( this set was sold like this). I just want to know if it will do any long or short term damage? and whether it would be better to get some 205/60 tires for the front or keep the 195/60's ? as i will need to replace the fronts anyway so id like to find out before hand.
Thanks guys! =)
Last edited by Phensteel; 11-21-2012 at 03:31 AM. Reason: lol typo i put back instead of fronts
Old 11-18-2012, 10:55 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
You won't do any damage unless both rear tires are different. Just don't run different sizes in the rear and you're good.
Old 11-19-2012, 06:04 PM
sweet thanks for that , What psi should i have all around? i have been told multiple figues but based on ur knowledge of e36 and the tyres i have listed above =)
Old 11-19-2012, 10:54 PM
BustedE36 BustedE36 is offline
E36 ///M3 Clone 328iS
Mein Auto: E36 M3 Clone 328iS
i run 215/40 in the front and 255/45 in the back also my rear wheels are 1.5" staggered ( Wider than the front wheels )..it stances out really nice i run 30-35 psi all the time.
Old 11-20-2012, 09:43 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Those tire sizes you listed all have different circumferences...
If you like driving straight, make sure both rears are the same.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 11-20-2012, 02:25 PM
Who? i know my setup drives perfectly straight, and drifts perfectly sideways!
Old 11-20-2012, 03:09 PM
petriej's Avatar
My apologies for being ambiguous.
OP listed the following sizes:
(Circumference)
215/60/15 (2006.8mm)
205/60/15 (1969.2mm)
195/60/15 (1931.6mm)
If your rears do not match each other, you'll have issues.
Otherwise, feel free to stagger the fronts to the rears. BMWs come stock that way to induce understeer, which, according to BMW is safer for the non-experienced driver than oversteer...
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-20-2012, 09:46 PM
oh d[I]ear no sorry i may have miss comunicated ,
The Sizes i have on my my E36 318i are as follows:
Fronts- 195/60
Backs- 215/60
on 15" rims
just to clarify.
So having a size down on the fronts is in reality continuing the same standard setup as the stock set up, just upsized?
Old 11-21-2012, 01:01 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i Hellrot Red
Yup. You'll be fine.
Just make sure front tire size match each other, and the rear tire size matches each other.
http://www.google.com/search?hl=en&t...iw=320&bih=416
Patrick ///98 328i hellrot///BMWCCA#465139
Old 11-21-2012, 03:28 AM
Hey,
thanks guys really appreciate the help, i'm a Noob with these beauty cars =P
I have decided to go from 195/60's on the front to 205/60's tires to fill the the space and balance her out more.
So ill have:
2x 205/60's 15" alloys = fronts
2x 215/60's 15" alloys = backs
Let me know if u disagree! =)
Old 11-21-2012, 08:11 AM
nothing.
Mein Auto: ItAintUrShtYUCare?
i disagree.... why are you so set on having staggered tire setups? seems very stupid to me
nothing.
Old 11-21-2012, 08:31 AM
petriej's Avatar
If you're able, match the fronts and the rears. It will drive better.
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-21-2012, 08:51 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, there is really no point in having staggered tires. They produce understeer and make it impossible to rotate the tires from front to rear. It's a lose/lose in my book.
1998 BMW 328is
1966 Pontiac GTO
Old 11-21-2012, 09:44 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
#swag
Old 11-21-2012, 06:56 PM
thanks guys,
I will Rethink what sized to push to.
So do you all recommend bumping the fronts to 205 or 215 to match the rears?
Old 11-21-2012, 07:31 PM
ZeGerman's Avatar
Warm Leatherette
What wheels do you have?
1998 BMW 328is
1966 Pontiac GTO
Old 11-21-2012, 07:50 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Staggered wheels look sharp, but on a car like this with such little power and that's so well balanced, they won't improve performance.
Now, as for staggering the tire sizes but using the same wheels front and back, well, that's just silly and is both bad for performance and aesthetics.
Sent from my Galaxy Tab using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 11-21-2012, 08:29 PM
yes i have heard that above as posted im asking another question.
The 3 series came staggered already as manufactured.
Im simply wanting to stick larger tyres on which i have done for the rears.
if im to replace the front tyres is it better to put 205/60's on them or should i match the rears with 215/60 as well?
@ZeGerman i have some original 15" or maybe 16" alloys there "cross spoke 78"
Old 11-21-2012, 08:43 PM
ZeGerman's Avatar
Warm Leatherette
Only the '96-99 M3 came with staggered wheels & tires. All other E36s have a "square" setup, meaning all four wheels & tires are exactly the same. Unless you have M3 wheels, which you apparently do not, you should match all four tires.
I'm not sure what wheels these are, but they aren't original to the E36. At any rate, just make all four tires the same and be done with it.
1998 BMW 328is
1966 Pontiac GTO
Old 11-21-2012, 11:05 PM
i had m3 wheels on but two got busted.
Thank you for your input, i will probably put 205's on the front as im just comuting with the baby.
It alright to fitt the bigger tyres on isnt it?
Old 11-22-2012, 07:22 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: 1995 318is
Yeah, you'll be fine with 205s in the front.
-CJ
Old 11-22-2012, 07:37 AM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
if you go wider without reducing the aspect ratio you will be running to different circumference tires. it's not much, but will affect the speedometer and not allow you to rotate the tires front to back.
of course if you wanted to drop aspect ratios accordingly, you'd be looking to get a 215/55/r15. good luck with that...
the closest tire size i could find would be 225/50/15.
i'd look for a set of 16" wheels myself...i don't think that even the e30 guys run 15's anymore...
df
Old 11-22-2012, 12:36 PM
How can you tuck such wide tires unless you have wheel spacers , 60 indicates width, please correct me if I'm wrong
Sent from my C771 using Bimmer App
Old 11-22-2012, 01:28 PM
cj.surr's Avatar
some kid
60 is the height. The first number (205) is the width.
-CJ
Old 11-22-2012, 01:30 PM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
The first _usually 3 digit_ number is the tire tread width in mm.
The second is the height of the sidewall as a percentage of the tread width.
The third number is the wheel diameter in inches.
Read this link for further details.
http://www.coasttire.com/tires/readsidewall.asp
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
