E36 (1991 - 1999)
Old 05-11-2012, 03:13 PM
tchavera tchavera is offline
Mein Auto: 323is
cat delete question
k so the comb in my cat is broken a little and the rattle from the inside is so annoying. i just passed emissions so i want to remove the cat. i don't want to do a straight pipe all the way, i want the muffler. does anyone know where i can find a pipe that is bolt on in place of my cat? i know it's out there i just can't find it. i don't want any cutting or welding. thanks
Old 05-12-2012, 05:22 AM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
nothing would be available that would be 'legal', so no. i don't think that you'll find a direct bolt on product. shops won't do it, wither, as it is a federal clean air act violation to remove the cat without replacing it on a street car.
your options are deal with it, turn the radio up, or manage to get a different exhaust to either replace or fabricate and swap it out.
either way, there is most likely going to be cutting and/or welding of some sort.
df
Old 05-12-2012, 07:29 AM
Mein Auto: 323is
Oh okay. I've seen bolt on replacements for mustangs. I guess I'm gonna have to blow the cone out. I don't know anyone reliable to make one
Sent from my SCH-I500 using Bimmer App
Old 05-12-2012, 12:13 PM
jaguarx7 jaguarx7 is online now
DON'T PANIC
Send a message via AIM to jaguarx7
Mein Auto: 1994 325is
If you remove the catalyst from the system you will get a check engine light. Best suggestion is to find a decent used set, they sometimes appear on craigslist.
Cars are much more compact if you don't take them apart.
There is a theory which states that if anyone ever figures out how and why the universe came to exist it would instantly dissapear, and a less rational, more complicated one would replace it.
There is another theory which states that this has already happend...
Old 05-12-2012, 01:18 PM
Mein Auto: 323is
I can deal with a check engine light but I figured why not leave an open space. I'm sure it will give a little more power and won't sound obnoxious
Old 05-12-2012, 01:26 PM
DinanM3e36's Avatar
DinanM3e36 DinanM3e36 is offline
WayTooFastWhitey
Mein Auto: Dinan BMW M3 e36
Depends on where you live if you'll fail inspection or not on a cat delete (here in tx you can pass in certain counties and fail in others, Dallas does smog testing but my current county (Wichita) doesn't)
Old 05-12-2012, 02:14 PM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
No one makes nor sells bolt on "test pipes" for BMWs.
Easy solution is to remove the cat, cut 2 inch square on top of it, ice pick the material out of, weld the 2 inch square metal back on it. But back on the car.
Old 05-12-2012, 02:24 PM
DinanM3e36's Avatar
WayTooFastWhitey
Just knock all the honeycomb crap out of the stock one with a long flathead and hammer it's just ceramic like material and breaks apart easy
Old 05-12-2012, 02:34 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: 1992 325is
No you won't
Also, you could buy an AA track pipe, but those are like $550... not worth it IMO.. This is what mine looks like..
I just cut out my cats and welded in straight pipes.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 05-12-2012, 04:51 PM
Mein Auto: 323is
thanks for your help guys. i didn't want to break up the comb because when i have emissions i could put the cat back in as it passed last week. i found a guy who will cut it out and put in a pipe. performance gain? if not who cares.. i'm not trying to buy an exhaust set up
Old 05-12-2012, 05:39 PM
DON'T PANIC
As his car is a 323is, he will have a check engine light because his car is OBD2. He has 2 O2 sensors, and the one after the cats are there to make sure the cats are doing their job. If the cats are plugged or broken the sensor will detect this and throw a code and check engine light. Only way to fix this is to get an O2 sensor simulator, but your engine performance still won't be optimum. I actually have seen test pipes online for sale online, but they're almost as expensive as a new set of cats. Bottom line is if your cats are broken it is highly recommended that you just replace them.
Old 05-12-2012, 05:44 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
obd2 gets a CEL
obd1 doesnt get a cel because the only 02 sensor is precat
Turbo lag is actually a headstart to make it fair
Old 05-12-2012, 07:33 PM
DinanM3e36's Avatar
WayTooFastWhitey
Do this muffler/cat delete...electronic valve control back pressure, custom switch to adjust to your liking (pull the cel bulb out jk)
S54
Old 05-13-2012, 12:50 PM
Moeman10's Avatar
hookersandblow
you're driving a 323, you will see power gains from yanking your cats.
Old 11-19-2012, 02:54 AM
Mein Auto: 2007 335i
OP, how did this work out for you? I am thinking of doing something similar.
94 318i, 97 528i, 07 335i
Old 11-19-2012, 09:29 AM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
"I dont always sleep on luxury executive sedans but when I do I choose Bmw.". Excellent sig pic.
Old 11-19-2012, 10:37 AM
BustedE36 BustedE36 is offline
E36 ///M3 Clone 328iS
Mein Auto: E36 M3 Clone 328iS
Bahahahaha win win win, the most interesting cat in the world eh?
