2005 X5 Dash Lights - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 11-24-2012, 04:37 PM
grhProfiler grhProfiler is offline
Mein Auto: 2005 X5
Question 2005 X5 Dash Lights
Hi,
I have a 2005 X5 Diesel and all of a sudden I have no odometer, trip and outside temp light. Does anyone have any ideas. I have also just installed a Hualingan HL-8786GB DVD\GPS and cannot work out how the GPS works, I can pick a location to find and then it will sit at that location and not start to move. Thanks
Old 11-24-2012, 09:58 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Id suggest rechecking your work...especially in installing an aftermarket unit in the dash. The MID/Nav unit that your removed is connected to the I-bus...and the instrument cluster is a major gateway component in the car's communication bus system (all roads go through the instrument cluster). If you lost info in the cluster after the Huligan install...you may have interrupted data in the cluster.
Q {BMW CCA Member #191509}
(SOLD)
Old 11-25-2012, 01:45 AM
Mein Auto: 2005 X5
Thanks man, I will get them to check it.
dashlights, hualingan hl-8786gb, x5
