E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
sweet 1995 325i convertible
I bought a 1995 325i convertible for my Daugther July of this year. Has run great until this last week when it just stopped. Turns over and will fire with a drop of starting fluid. I let it sit a couple days and it fired and ran perfectly all day....then nothing the next day. I do not hear the fuel pump engage. Lifted the back seat and put a meter on the fuel pump plugs...with key on the white plug reads 12 volts, the black plug 0 volts. I had the key turn the engine over and still registered 0 volts on the black plug....the relays all click when the key is on... I applied 12 volts to the disconnected fuel pump...it runs....now what
Possible: Fuel pump relay. Clicking means nothing. They can click and still not work. More likely: crank position sensor.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Any way to test crank position sensor?
I swapped Solenoids with the same numbers and colors... Light green ones with the number 464.....with no result. Not sure witch solenoid runs the fuel pump though... I do not sense the fuel pump running with one hand on the key and the other on the pump. When I powered the pump directly, it was pretty quiet. Did not rev very high to my mind. I tried powering the pump directly while my kid turned the key....nada, reversed polarity...nada I was hoping for a straight up diagnostic, but this is part of the joy...mixed signals Last edited by SpinfisherBob; 11-19-2012 at 01:55 PM. Reason: addition idea |
I have located the fuel pump relay...N0. 1 in the Haynes manual, cleaned contacts, replaced...nada
I know I have spark cause she fires with a drop of starting fluid...I'm strongly leaning to throwing a relay and the fuel pump at her....there is a circuit diagram on the side of the orange BMW relay....will try test the relay on the bench next.... |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
