Old 12-01-2012, 01:37 PM
bimcwe bimcwe is offline
XIL
Mein Auto: 2002 325xi
Exclamation Belt? Pulley? Or leak? Car is making a horrible sound.
I've got P0491 and P0492: "Secondary Air Injection System Insufficient Flow".
And I just replaced all the intake boots, checked them again this morning, cleaned my MAF, Throttle Body (both already cleaned a week ago) and replaced the vacuum tube running from the CCV to the back of the engine area (that was very annoying to get to). I did all this because I thought somewhere in there was a crack, and thus a leak, in some rubber (the vacuum tube had broken). Light still on.
When I turn the car on, when I accelerate, when I sit at idle... this sound... this sound
Car is running limp'ish and rpms drop a little bit randomly every once in a while.
Help.
Dreaming of the ///M.
Old 12-01-2012, 03:35 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Take a spray bottle with water in it, squirt some on the idler pullies, and start it up. If the noise stays gone for a minute or two, you nailed the culprit....
The road goes ever onward....
(R.I.P. Jever)
Old 12-02-2012, 04:57 AM
XIL
Thanks Bob, that seems to be the issue. Ordered a new pulley from Max. Should be here soon
Also, could that somehow be causing those codes?...
