Old 11-19-2012, 09:52 AM
babyZ babyZ is offline
Enthusiast
Mein Auto: 1997 BMW Z3
Z3 Traction Control light
The traction control beacon lights up regardless of conditions I am drving in and remains on any time I am behind the wheel.
Any insight as to why it would and what I can do to shut it off?
Old 11-19-2012, 01:20 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Quite commonly, it's a faulty wheel speed sensor. If inspection doesn't show anything obvious, you might want to have the codes read.
Old 11-19-2012, 02:21 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
you can try removing and cleaning the wheel sensors. They do attract "metal" over time and that can build up.
Also check/clean the connectors for each sensor.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 11-20-2012, 11:02 AM
ECSTuning's Avatar
Mein Auto: e30
Sounds like a speed sensor. Try cleaning it off, if that doesn't work it's time to replace it. I have the new sensors available HERE.
800.924.5172
OEM BMW Part Number Search
Old 11-20-2012, 05:49 PM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
codes
READ THE CODES before making any decision. Ask me how I know??
