Old 11-19-2012, 01:58 PM
Vrezzy Vrezzy is offline
Mein Auto: 2001 5301
Passenger seat stuck in rear position
Have visited forum many time to help in repair issues. I have encountered a problem that I have not seen posted before - 2001 e39. The passenger seat was moved rearward and will now not move forward. I can remove the seat because it is stuck in the rear position with the seat over the bolt. I have determined that the switch module works -checked continuity. So I believe that something is either jamming the rail or the motor is no longer working. I think I would be able to diagnose the problem if I could get the seat out. Any ideas?
Old 11-19-2012, 02:21 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I assume you've checked the connectors behind the finisher where the switches are mounted, and those under the seat.
Do any other seat functions work?
Old 11-19-2012, 02:26 PM
All the other seat functions work with there switches. What little wiring I can see under the seat seems to be in order. The one connector to the drive motor near the door is in place.
