E36 (1991 - 1999)
warning lights showing on the computer
I have warning lights showing on my computer that my brake lights are burned out and they are working fine. Also show coolant is low but it is OK.
It's your brake switch. You have either a four wire switch or a three wire. The only way to tell is to look. Here's the DIY http://www.pelicanparts.com/bmw/tech...ake_Switch.htm. Break the old one off with a big set of pliers-- its a PITA to remove. The warning message states "Brake circuit failure" right?
Coolant message could be harness fallen off connector, or bad sensor. Take a look along the passenger side, at the bottom of the reservoir to ensure the connector / harness is plugged in. Sometimes they will work loose, and other times the clip part is broken and will let the thing work loose from vibration. Here's a picture of the location I copied from a site that was a banned link for some reason ![]() image sharing
It's not what you buy, it's what you build- Unknown EN90283 - Stabled for HG repair DH06247 - Running like a champ Last edited by mgoods50; 11-20-2012 at 03:46 AM. |
