Blown Head Gasket, Any mods to do while in in there? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 11-19-2012, 11:41 PM
ssbandit158 ssbandit158 is offline
Mein Auto: Black 1996 BMW 318i
I have a 1996 318i with a blown head gasket. Has anyone ever shaved a few thousands off the head to give it a little more compression or am I better off leaving it be. Also is there any routine changes I should make in there while I have the head off? Thanks in advance.
Old 11-19-2012, 11:43 PM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
If the head warped you will have to anyway. Cams to start.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 11-20-2012, 12:19 AM
BustedE36 BustedE36 is offline
E36 ///M3 Clone 328iS
Mein Auto: E36 M3 Clone 328iS
Dont chance it resurface the head it cost me $50 at a local machine shop..better than blowing another gasket!
Old 11-20-2012, 05:16 AM
Yeah I will be checking for warping when the head is off. Are cams really worth the money on a 4 cylinder? This car is a daily driver used for good gas mileage... Now if I could put some cams in there that got me better mileage then I'd be all about it
Old 11-20-2012, 05:46 AM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Just drop an I6 in there...
Sent from my Nexus 4G using Bimmer App
You wont be able to tell by the eye if it is truely warped..not even with the straight edge, just saying.
Old 11-20-2012, 05:53 AM
What does a machine shop use to check for warping? I would think using a machinist straight edge would be accurate enough to seal a gasket right? I'm no mechanical engineer so my answers are pure speculation on my part but common sense would tell me that would suffice I would think. Now checking for cracks on the other hand would have to be done at a shop.
Old 11-20-2012, 05:58 AM
They magnaflux it to check for cracks and have a special machine i would presume to check for warpage, but its inexpensive and it adds compression like you said..just saying most people that are doing a HG wouldent skip that step.,are you doing the whole procedure on your own?
Old 11-20-2012, 06:05 AM
Yeah I'm doing everything in my garage, I got the intake off yesterday and today am going to work on the rest. My gasket kit comes in Thursday so I'm starting early hopefully to get it all apart and cleaned up and ready to reassemble during the weekend. I'm sure I will have the head shaved to get it straight at a minimum.
Old 11-20-2012, 06:09 AM
Cool i just did my HG about a month ago..heres a tip if you dont know already, dont just take the caps off the camshafts because they are brittle and lightweight and you risk bending and cracking the cams..if you check the pelican guide it says to use the rope technique which is alot easier than it seems when you first read about it, (Placing a few pieces of rope bheind each valve reliving pressure from the camshaft, on both intake and exhaust side then using a valve spring compresser to take them out once the cams are back in.) oh and a 6" x 1/4" keystock and 2, 2" C clamps to hold your cams in place when you are putting your vanos back on and timing.
Old 11-20-2012, 06:19 AM
Awesome, thanks for the heads up. My car is an i4 so I don't have vanos, so that should make things a little simpler hopefully.
Old 11-20-2012, 06:24 AM
Yep no problem good luck it took me about a week to do mine but i only did a few things everyday and took my time, it may seem over whelming once the intake manifold is disconnected with all the vaccum crap hanging off, but it all goes back together fairly easy. good luck dont hesitate with the questions
