Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 11-20-2012, 04:58 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
BT Audio
Quick question, when I use my Android phone for bluetooth audio streaming, no song info on the I Drive, if I were to use a USB cable, would I see this info, also would I able to
control via the I drive instead of the phone, seems that Android phone are the bastard stepchild of BMW.
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 11-20-2012, 08:55 AM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: '11 X5d
Streaming:
Depends. What phone are you using? Another thing is what app you're using. If its the built-in song player, then the audio's meta data will be shown on the iDrive. However, if you are using streaming audio apps, such as Pandora/MOG/Spotify, etc, no, you won't get any meta data, but you can use the steering wheel controls to skip songs.
Plugged in:
Also a little iffy. My newer Galaxy S3 is quite finicky and sometimes doesn't get recognized when I plug it into the USB, but you also have to make sure what "USB mode" its in. If you have music on the internal storage and you plug it in (and it mounts correctly), theoretically, it should work fine. All meta data info plus album art. But you won't be able to use Pandora/etc over USB because BMW doesn't support that yet.
Yes, BMW seems to hate Android
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather
Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production
Old 11-20-2012, 09:20 AM
ductman's Avatar
Originally Posted by AutoUnion View Post
Streaming:
Plugged in:
Thanks for the info, I am using a Motorola Atrix 2, BT streaming works with the apps, steering wheel controls do not work to skip songs though at least on my particular phone.
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 11-21-2012, 10:46 AM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
These comments are for an iPhone 5 . . . may or may not match OP's Android case. Writing this post in case folks with iPhones are reading this thread.
I have the BMW supplied Y-cable - MY 2011, June 2010 build.
When iPhone is connected to the Y-cable, everything works - playlists are displayed on iDrive, iDrive controls and steering switches all work.
When iPhone is connected via a BT audio (I use Blackberry Music Gateway plugged into the audio jack) only audio part works - i.e. you can hear the song/podcast but nothing else. All you control from the steering wheel is volume.
By mistake I left the USB end of the Y-cable plugged in (with iPod attached to the Y-cable) and plugged the BB Music Gateway to the audio jack. In this case I saw the *iPod* (not iPhone 5) playlist on the iDrive but the audio was from my iPhone 5.
Old 11-21-2012, 06:59 PM
macming macming is offline
Mein Auto: E46 M3, 2011 X5 35i
What does the Y cable get you that a regular iphone USB cable doesn't?
Old 11-21-2012, 07:01 PM
AutoUnion's Avatar
Mein Auto: '11 X5d
Basically nothing. As long you have the COMBOX (post 10/10 production), you don't need to use the Y cable. You can use the regular white sync cable
Old 11-21-2012, 07:04 PM
Oh, mine is Aug 10. I guess there might be some benefit?
Old 11-21-2012, 07:05 PM
Nothing . . . mine is simply the older model (BMW audio engineer simply didn't get around to doing the obvious!) . . . missed the regular white cable by a few months . . . more cable mess but fortunately it is out of sight!
Old 11-22-2012, 08:05 AM
ductman's Avatar
My wife's Infiniti, I tried using the BT Audio today with Pandora and guess what, the steering wheel controls change the station, where in my X5, no go, again BMW hates Android
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 11-22-2012, 10:50 AM
AutoUnion's Avatar
Mein Auto: '11 X5d
I just went out and tried it again. Pandora and Spotify worked perfectly on my Galaxy S3. Try again?
Old 11-22-2012, 03:58 PM
ductman's Avatar
Tried again, also tried the USB ports also, BT audio streams, only way I can change songs is thru the phone itself, only the volume button works on the steering wheel.
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 11-22-2012, 04:12 PM
AutoUnion's Avatar
Mein Auto: '11 X5d
What software version are you on?
Old 11-23-2012, 06:37 AM
ductman's Avatar
Multimedia Version MX-003.004.031
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 11-23-2012, 11:59 AM
AutoUnion's Avatar
Mein Auto: '11 X5d
Oops, I meant what version of Android are you running?
Old 11-23-2012, 04:07 PM
ductman's Avatar
I just updated to 4.0 Gingerbread today, that also did not do the trick, thanks for your help.
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 11-23-2012, 04:57 PM
AutoUnion's Avatar
Mein Auto: '11 X5d
4.0 is ICS, not Gingerbread
Maybe you need to update your bluetooth update for the iDrive?
(from www.bmw.com/bluetooth , enter your VIN and put the firmware bin file on a USB stick and upload the file into your iDrive via the BMW Firmware Update section.)
If that doesn't work, then it has to be something with Motorola's software. All my old Sammy and HTC Android phones work fine with the iDrive's A2DP controls.
This whole situation is weird because both the Atrix and iDrive support A2DP (streaming BT audio) and AVRCP (BT controls), yet they don't seem to like each other
Old 11-23-2012, 04:59 PM
AutoUnion's Avatar
Mein Auto: '11 X5d
UPDATE: just looked at BMW's website and it specifically outlines that "fast forward/reverse" isn't supported, but does say that it can be operated "via control display"
Old 11-23-2012, 05:45 PM
ductman's Avatar
Just got it to work finally, it will only work thru the I Drive controller ( Pushing down ) on the
" fast forward/reverse " that supposedly is not supported but it will still not work thru the steering wheel controls, again thanks for your time.
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
