E36 (1991 - 1999)
Old 11-20-2012, 12:30 PM
Chache320i Chache320i is offline
Mein Auto: BMW E36 320I
Fuel gauge, tells empty ... :(
I have 320I, e36 with 150hp, it's like brand new... but there is a problem... the fuel gauge is always on empty... red light is on... (reserve) but in the fuel tank, i have 1/2... and also the right indicator, on the dashboard is dead... no blinking ....
Sorry for my bad English .
Respect !
Old 11-20-2012, 12:33 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Sender is likely dead
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 11-20-2012, 12:49 PM
i read some texts.... some guys r saying that I need to remove fuse 46, key on position, back fuse 46, and should work ... i'm so confused ....
Old 11-20-2012, 12:52 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I've heard of the fuel gauge going a little crazy after filling up the fuel tank with the car running, which is remedied by disconnecting the battery. You can try this, but in all likelihood you need a new fuel level sending unit as Phantom mentioned above.
1998 BMW 328is
1966 Pontiac GTO
Old 11-20-2012, 02:14 PM
I'll chek it tomorrow, if the fuse trick works, i'll be so happy... but it doesn't work ... i'll need to buy fuel pump, and all of the stuff ...
Old 11-20-2012, 02:44 PM
ZeGerman's Avatar
Warm Leatherette
1) Nobody said to replace your fuel pump (or "all of the stuff")
2) It's most likely your fuel level sending unit/sensor, and
3) I recommended to disconnect the battery, not remove a fuse
1998 BMW 328is
1966 Pontiac GTO
Old 11-20-2012, 03:34 PM
ok, but what is wrong with the blinker on dashboard ? disconected wire or somthing ?
Old 11-20-2012, 03:41 PM
ZeGerman's Avatar
Warm Leatherette
Is it blinking on the outside of the car, but not on your instrument cluster? If so, replace the indicator bulb behind your instrument cluster.
1998 BMW 328is
1966 Pontiac GTO
Old 11-20-2012, 11:50 PM
yep is blinking outside, maybe loose wire or bulb ...
Old 11-21-2012, 12:47 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Fuel is probably the sending unit. Disconnecting the battery could reset it and bring it back to life...
The non blinking bulb, is a burned out bulb in the cluster. It's easy to come out, 2 torq screws and you're all set.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
