Old 03-01-2013, 08:45 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Originally Posted by jpimpao01 View Post
Please last SP files for R56.
Thanks.
PM Sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 03-06-2013, 01:54 PM
sean18337 sean18337 is offline
Mein Auto: ///M
HI Sahwn,
Can you send me the latest SP and Daten files for E70..?
Thank you in advance!
Old 03-06-2013, 08:09 PM
Originally Posted by sean18337 View Post
HI Sahwn,
PM sent.
Old 03-06-2013, 09:56 PM
melloww22 melloww22 is offline
Mein Auto: 2011 e90 335
Shawn,
Can you PM the link for the Full 48.1 SPDaten...
Thank you Sir.
Old 03-06-2013, 10:01 PM
Originally Posted by melloww22 View Post
Shawn,
Thank you Sir.
PM sent.
Old 03-06-2013, 11:19 PM
munxayzen munxayzen is offline
Mein Auto: 320d
ThanK you!
Old 03-06-2013, 11:22 PM
PM sent.
Old 03-06-2013, 11:38 PM
Mein Auto: 320d
Originally Posted by shawnsheridan View Post
PM sent.
And if I have version 47.4 can I somehow upgrade to 48.1 without downloading 20 GB
Old 03-07-2013, 02:12 AM
camelush camelush is offline
Mein Auto: 1995 E36 BMW 320i
ThanK you!
Old 03-07-2013, 07:33 PM
Sometimes you can get away with just adding the new CAFD's to your older PSdZData, but it is not advisable. Often one or more of the new CAFD's also requires the newer supporting binary files (.jar, .dll, etc.) in order to work.
I will though be releasing a 49.0 PSdZData Lite version, which will weigh in at 3 Gb instead of 13 Gb. This will be fine for coding, but can not be used for flashing.
Old 03-07-2013, 07:37 PM
ThanK you!
I assume you mean SP-Daten. PM sent.
Old 03-09-2013, 02:18 AM
nasvi1895 nasvi1895 is offline
Mein Auto: 328i M-Sport
Hello shawnsheridan,
Can you please PM me with the link to 48.1.
Also does this work with E-sys 3.18?
Thanks in advance
Never mind the last question.
Found your answer to that at "http://www.bimmerfest.com/forums/showthread.php?t=669629".
Old 03-09-2013, 09:07 AM
Thanks in advance
PM sent.
Old 03-10-2013, 09:45 PM
Mjf404 Mjf404 is offline
Mein Auto: 2013 F30
Hi Shawn.
I am just getting started with coding. I read your E-Sys set-up directions. Thanks! I am currently pulling the PsdZdata 47.5 from torrent. Could you PM me a link to the 48.1 PsdZdata update files? Going to give coding my 2013 F30 a try.
Thanks for all you do on the forum!
Old 03-10-2013, 10:08 PM
Originally Posted by Mjf404 View Post
Hi Shawn.
PM sent.
Old 03-11-2013, 04:18 AM
pashkustva pashkustva is offline
Mein Auto: e83
hello shawnsheridan
could you spare a link for a daten files v 48.1 to me either
pashkustva@gmail.com
thanks a lot
Old 03-11-2013, 04:40 AM
Originally Posted by pashkustva View Post
hello shawnsheridan
thanks a lot
PM sent.
Old 03-11-2013, 11:38 AM
Mein Auto: 2013 F30
Thanks for the help. Your instructions are great for a first-timer. I think that I am going to need the 48.3 PsdZdata. I am getting the CAFD not found error, in several modules. The dealer did update the software when I had them look at a loose taillight last month. Should I upgrade from Esys 3.18.4 to 3.22 while I am at it?
Old 03-11-2013, 07:13 PM
You need to upgrade.
PM sent.
Old 03-12-2013, 07:20 AM
indeed indeed is offline
Mein Auto: F20
Hi shawn, May I have the link to update? Thanks!
Old 03-13-2013, 05:45 AM
PM sent.
Old 03-13-2013, 12:36 PM
daleel_2020 daleel_2020 is offline
Mein Auto: lebanon
Link PLZ
Dear Shawn,
Thank you in Advanced.
Old 03-13-2013, 08:03 PM
Originally Posted by daleel_2020 View Post
Dear Shawn,
PM sent.
Old 03-15-2013, 02:42 PM
hendriks hendriks is offline
Mein Auto: F25
Thanks for this great Thread!
I've E-Sys 3.18.4 with PSDZDATA 46.3, this installation works fine. But not for my new 2013 F25 (ErrMsg: cafd file not found).
After reading some posts, i have decided to updated to PSDZDATA 47.5 - yet, i can't no longer connect to the car:
Set PSdZ-Root using "C:\ESysData" failed! [C073]
KIS start failed: Cannot open connection [1689] - SYSTEM_ERROR
I think, the PSDZDATA 47.5 is corrupt...
Could you send me a link to the 47.7, please? And is this version good for my 2013 F25?
Thanks for your help.
Greetings from Switzerland
hendriks
Old 03-15-2013, 04:12 PM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
hendriks
You should start with 48.3 or later.
