E90/E91/E92/E93 (2006 - 2013)
Old 11-20-2012, 04:56 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW E90 2007
Anybody did their N52 valve cover themselves?
It was changed once under warranty. Still leaking 2-3 years later - poor design IMO. I wouldn't touch it (1 ltr / 2200 miles) but starting the car cold, I see some smoke from that area if I open the hood.
It is a job I did on other cars but this one is a bit nasty and not your regular one. 5-600$ at the dealer I was told. However looking at my Bentley (113-3/4/5), it doesn't seem that bad. I know that 2007+ were upgraded with different bolts.
Any actual experience?
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
Old 11-20-2012, 05:21 PM
DSXMachina's Avatar
Automaticallyparsinglinks
Yup, lots. Can't say why, but that area where yours is leaking seems to be where 9 out of 10 leak. Then it runs down the head right onto the hot exhaust manifold and that's why it is such an annoyance.
Try the job yourself. If you can follow a guide, and there's lots of them, you can do this without a hitch. Be careful unclipping the coil harness, and watch out for the wires at the back of the cylinder head especially when you're reinstalling the cover. You sure don't want to trap them between the cover and the head when you torque down the cover.
Use new aluminum screws of course. Use a complete new gasket set with all the seals in it. Be sure to use a dab of sealer on the head next to each cam end seal corner. We use red silicone, you can use the BMW stuff if preferred.
Look closely at the space between the cover and the head before you take off the old cover. It's uneven, and will still be when you install the new gasket set. If you don't notice this varying gap before you start you will go nuts when you're done thinking you did something wrong. No, it was the BMW engineering dep't which spec'd it wrong. It's plastic and should have been aluminum.
[My guess as to why it's still leaking after being changed on the warranty: It wasn't changed. The area was cleaned up with sovent cleaner (usually brake cleaner), then the screws were tweaked down a little tighter and the job was shipped.]
Old 11-20-2012, 07:06 PM
Lufthansa Lufthansa is offline
Mein Auto: 2010 E92; '07Lexus GS350
DSX,
Just curious - the OP's 328 is an '07. From your experience, was this issue resolved on newer 328's?
Thanks.
Old 01-09-2013, 02:39 PM
Saintor's Avatar
Well I am happy that I didn't bite on that one by doing it myself. The valve cover itself needed to be replaced. Expensive repair, though (1040$+txs).
Old 01-09-2013, 05:19 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
I have done a few. It is not that difficult at all.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 01-09-2013, 07:57 PM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
I personally have posted the DIY for this & eccentric shaft sensor twice in the past few days....
Have you seen it?
Then again, you might want to use the BMW maintenance procedure directory.
Before you click on the last, you got to ask yourself one question: "Do I feel lucky?"
Well Saint, do ya?
Old 01-10-2013, 03:23 PM
Saintor's Avatar
Have you seen it?
Well Saint, do ya?
Not interested in this kind of smart-ass replies, like "Let me Google it for you". Anyway it brings a DIY for a M54 engine, * irrelevant *.
Old 01-10-2013, 03:26 PM
Saintor's Avatar
If you are talking about the cover itself, you are 100% right.
Old 01-11-2013, 06:38 AM
Aha! Not interested, yet you checked it and were compelled to post on it.
The answer to your issue's in there.
