Hi, my right rear tail light is not working. I get the dash message "check brake lights". I swapped the bulbs with the left side and all bulbs work. I took 12v dc across the connector pins on the lamp, and all bulbs work. The running lamp works fine as it normally would. The high mounted stop lamp doesn't work (bulb is working fine). Any suggestions?
What year and model. On my 04 330i the light was on I took it to BMW to have the oil changed the guy there said there was a recall on the lights something about not being grounded right. Maybe that's your problem they did it for free so .
Sent from my Galaxy Nexus using Bimmer App |
Did you check the connector for corrosion?
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
Yes. I checked for corrosion on the connector, and it really clean. Not a hint of corrosion.
Sorry for not being specific on the model. It's a 2003, 530i, manual transmission. The ground looks good. I checked the connector wire ground with the body ground and got very low resistance. I think that's good.
So the brake light, turn indicator, backup light and LED tail light all do not work?
I'm guessing that you need to replace the socket for the third brake light in the back window. It goes bad cause these symptoms and drives owners crazy until they replace it.
Correct. Also, the yellow flashing light that goes on when I lock the doors. It might be the emergency flashers, too. The only light that works is the running lamp. Also, the high mounted stop lamp doesnt' work.
Correct. The only lamp that works is the running lamp on the right side. The blinker, backup light, LEDs, and the yellow flasher that is used when I lock the doors (it might be the emergency flasher lamp, too, but I'm not sure). Also, the high mounted stop lamp doesn't work.
Hi. The high mounted stop lamp socket looks very good, too. No corrosion, no damage.
What do you guys think about this response that I found on: http://forums.bimmerforums.com/forum....php?t=1352393 ?
+++++++++++++++++++++++++++++++++++++++++ Just for information purposes...all external lights are controlled by the LCM (light control module)...there isn't a "fuse" that controls them...this can be verified by looking at the fuse index card in the glovebox and on the back of the battery compartment fold down door. (no fuses for external lights...take a look see) Can you reveal what made you remove the tail light in the first place? For those of us out here on the internet...it's as if a big piece of the puzzle is missing. Most people wouldn't remove an entire rear light assembly just to remove it (but I guess it's possible) ...could it be something else that is causing the problem? Last edited by butlerbp; 11-25-2012 at 02:26 PM. Reason: bad link to images |
tail light malfunction
Sorry, bad linkes to the images. Here they are. They're up on Photobucket.
http://i1356.photobucket.com/albums/...01995-1998.jpg http://i1356.photobucket.com/albums/...t20Info201.jpg http://i1356.photobucket.com/albums/...t20Info202.jpg |
OK, here are more symptoms:
--left front flasher doesn't work --left front halow lights don't work --left front LED doesn't work --Left front high beam doesn't work --left front flasher bulb works fine (I switched them from lt to rt) --back up lights don't work All other symptoms remain: --high mounted stop lamp doesn't work --right rear flasher doesn't work --right rear stop lamp doesn't work --right rear running lamps are ok --right rear LED are ok UGH! |
| Bookmarks |
| Tags |
| tail lamp failure |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
