The X5 SAV Forum
Old 11-20-2012, 08:35 PM
jaredt2121 jaredt2121 is offline
Mein Auto: 2004 x5 4.4i
how to guide for brakes
so i bought a kit with the sensor rotors and pads, but im trying to save what i can,
so i need a detailed how to guide on how to do this....
2005 bmw x5 4.4i
Old 11-21-2012, 06:34 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Do a search, this has been covered many times. Good luck.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 11-22-2012, 03:58 AM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
I changed the brakes and rotors on my 2005 X5 last spring. I found changing the brakes on the BMW very straightforward. (I helped a neighbor once replace the brakes on his Fiat Spyder in the 80s. What a pain that was; the worse brake design I ever came across.) Getting the spring clips off and back on the BMW calipers is kind of a trick. Once you have that mastered the rest is simple unbolt and bolt on. Most of my time was spent on cleaning. A lot of brake dust is hidden in those calipers. Here's a tip- I smear at thin film of anti-sieze compound on the face of the rotors where they meet the wheels. The wheels won't be so tough to remove next time. (I had to beat each wheel with a rubber mallet to break them loose from the rotors. The wheels had been on a while. I don't practice tire rotation. The tires wear perfectly all the way around so I leave them alone.) Also flush the brake fluid when you change the brakes. This is a good time to do it since you can get to the bleeders more easily with the wheels off. My last note- use a torque wrench and torque all of the bolts to spec when reassembling. That is important. Brakes are important. You can search the forums for the proper torque specs.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors
