Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 11-21-2012, 01:18 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
Brake and drive control systems malfunction
Got this message today. Also the brakes were locked and wouldn't release until the car sat for a while.
Initially I thought it was my transmission as the car didn't want to upshift and when I released the gas it would just slow down very quickly and stop. Few times of that and I got the message. So any ideas???
Any ideas on what part I might have to order????
All help is GREATLY appreciated.
Old 11-21-2012, 06:40 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I'd start by checking for codes. At least get the generic codes with a basic scanner. But, the manufacturers codes are what you want.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 11-21-2012, 11:52 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Does your car have that hill assist option? Once you are on an incline the brake is applied for a couple of seconds until you press the gas. This is on the manual cars but not sure if it might be on the auto cars as well. I could see where a malfunction in a gyro sensor could make the car think it's on an incline and is applying the brake. Just putting this out there because I am not sure what else could be causing that problem.
2008 650 Convertible- 6 Speed manual- Sport package- HUD- Lane Departure- Comfort Access- Merino Leather- HD Radio- SAT
Old 11-21-2012, 06:06 PM
HerbP HerbP is offline
That sounds like your calipers could be locking up, or possibly your brake lines might be swelling up & locking the calipers. Have you been working on the brake system lately?
Old 11-22-2012, 06:53 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Whatever is is, it sounds bad. Never seen this error mentioned before. I would get a mechanic to scan for codes. Could be something to do with the ABS/traction control module too.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-23-2012, 01:56 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
Hi ! there is a default position in the brake control function where you are given minimum bake assist control, but as you say it is on all for corners and you have a transmission error, I cannot think of any module that controls both, so follow Yorgi's advice and take or have it towed to a dealer......+1
Does my bum look good in this !
Old 11-23-2012, 04:51 AM
Woo Hoo FREE Donuts
I don't really have a BMW dealer option here. I am thinking about just ordering a new ABS module because it seems to me like it may be ready to die on me. However there is always the chance that Battery issues are causing the problem.
Car seems back to normal now but I only went back and forth in the driveway.
Here is a picture of the fault I was getting.
As I said there wasn't reduced braking as it seemed to lock up all the brakes. Pedal went brick hard. Steering stayed normal. No transmission faults or errors, but I believe it didn't want to upshift because it was probably thinking I was standing on the brakes. 5 mins of sitting and all was well again.
Old 11-23-2012, 10:51 PM
Yorgi's Avatar
I would not go randomly ordering an ABS control unit. If it is not battery related, you could also have something simple like a wheel speed sensor gone bad, which is what the ABS unit relies on for input.
'04 M3 - track
Old 11-24-2012, 01:33 AM
rebel.ranter rebel.ranter is offline
Mein Auto: 630i, 525i, 320iC
I'd agree, don't go ordering expensive parts needlessly. If you have no access to a dealer (I believe you are based FAR far away from home too from previous posts) you might be as well to get yourself equipped with a diagnostic kit based on INPA or DIS v57.
Old 11-24-2012, 08:28 AM
Woo Hoo FREE Donuts
Is there anything else that would cause the brakes to all lockup???
Old 11-24-2012, 08:29 AM
Woo Hoo FREE Donuts
Yes I definately need to get my own diagnostic tools.
Old 11-25-2012, 08:02 AM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
Dsc pump can cause that. I had a faulty harness going to mine in the 7 and had same thing happen.
650i sport hud asanti af132
Old 11-27-2012, 11:15 PM
Woo Hoo FREE Donuts
Thanks I will look into that.
Old 11-27-2012, 11:19 PM
Woo Hoo FREE Donuts
Drove the car today. No messages, no faults on the screen.
The brakes "seemed" softer than before. Brake pedal had a really soft squishy kind of feeling. Didn't do any abrupt stops or anything but it sure doesn't feel as solid as before. Could just be in my head.
