Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 11-21-2012, 04:04 AM
clinkinfo clinkinfo is offline
Mein Auto: x3,x5
2008 x5 amplifier
Hi all,
Having a problem with my 08 x5 voice command, PDC, and nav audio output. Dealer has diagnosed a bad amplifier (I do have dsp too).
If I swap it out for a new one, does it need to be 'reprogrammed' somehow by BMW?
Or if I plug in a working amp, should I instantly see the audio return to those functions?
Thanks in advance, just trying to understand if this can be an easy swap out fix on my end.
Old 11-24-2012, 04:49 AM
Mein Auto: x3,x5
For anyone following, after speaking to 2 dealerships they both indicate the amplifiers are not plug and play and require programming to function
