BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
BMW Deisel
Does the deisel get any better mileage than the gas version? Considering a diesel.
There's a big diesel subforum here on bimmerfest.
Quick answer is yes. Check fueleconomy.gov and fuelly.com for fuel economy estimates & reported FE. Last edited by d geek; 11-22-2012 at 08:07 AM. |
+ as Geek says. I get 5-8 mpg better than my son's 335i. Sometimes even a bit more. Unfortunately, diesel is a fair bit more than gasoline right now but in the past it was less than premium.
If you drive one you will love it, and likely buy one. Be careful, it is a great car.
Gas mileage diesel is approx 30% better, but as badgerbob mentioned, its a lot of power for its size, in my world power is torque [low revving engine extremely strong pull from dead stop] but if you're more into high revving, horse power, likes down shifting kinda person than you may not like it. Fuel consumption wise diesel is better. Hope this helps. Good luck!
2011 335D Alpine White/Chestnut Brown, M-Sport, Premium, NAV.. 2012 VW Golf Wagon TDI White/Black, Highline, Pan Roof, Nav.. |
I think that 30% is on the high end, but it is possible. It is also possible to not see much if any improvement over gas if you flog the car heavily. Driving style accounts for a lot but overall diesel will give you at least 10-15% better mileage. There are trade-offs however. The smell of diesel is off putting to some (it is more aromatic than gas and the smell lasts longer), especially if it gets into the interior of the car through spillage on your hands or shoes. It can be hard to find -- although this is not really that much of a problem -- and it can cost more than premium -- again, not always, but sometimes. Over all it is a great fuel and the engines are built to last because of the very high compression required for ignition (no spark, just compression heat). The new high speed light weight turbo diesel engines are truly marvels (all makes, not just BMW) and they are worth your consideration. Just take your wife on the test drive and at least one fuel stop to see if she will buy off on the car!
Diesel fuel has about 15% higher energy content per gallon than gasoline. So it gets 15% MPG better given the same level of technology. To get above 15% MPG improvement has more to do with the tuning characteristics of the engine and how you operate. The BMW rates X5 35i as 16 in the city and X5 35d as 19 in city. That is pretty close to the expected efficiency from the fuel itself.
In Silicon Valley, diesel costs more than the premium fuel. The price tends to stay flat and constant due to lack of demand. So, your cost of operation may be slightly ahead to flat. I was ahead when the gasoline shot up due to southern California's refinery fires. I am now on par in cost because diesel moves slower. I got diesel engine because I like low end torque. Diesel does not rev as high as gasoline engine and requires more shifts. As the result, its 0-60 time is slower than gasoline engine. |
I guess I'm lucky to live in a area where diesel pumps are as clean as the gas pumps (no gloves needed) and where the price averages out over the course of a year to be roughly equal to premium gas. In the Summer diesel is cheaper and in the Winter gas is cheaper.
The 335d is the first car that I have owned that has averaged equal or better than the EPA highway rating in my everyday driving.
BMWUSA 650i xDrive Build Link ...................................BMWUSA X5M Build Link 2013 X5M ........ 2013 650xi ...... 2011 550xi (ret) 2011 335d (ret) ![]() ![]() ![]()
I have yet to have a diesel car or truck where maintenance and repairs were cheaper than their gas sisters when looking at overall costs for 225-300k miles of use.
--Aaron |
Down here 4-5 months ago diesel was abnormally low and below 93. That however has not been the case in past years. Like I said I have seen abnormal low spikes but for the most part for the past 8ish years down here diesel has been at or above the cost of 93 octane.
--Aaron |
just up the road in our area diesel fluctuates from a few pennies less than premium to a few pennies more than premuim has for years and still does. maybe its because we are more ag here than humble is??
11 335d 2010 S1000RR 08 K1200GT 08 WR250R |
Or maybe it is the costs of the gasoline that is more different there and bringing the difference down. I am Lubbock right now and diesel is about the same as Houston but gasoline is not. Also gas is slightly lower octane levels here for whatever reasons.
--Aaron Last edited by Snipe656; 11-23-2012 at 08:26 AM. Reason: spelling |
If you do a lot of highway cruising then the D is an excellent choice as it gives you great driving range and effortless performance.
If you do a lot of city (stop+go) driving then the FE is not good but still better than the gasser. If you are not in a hurry you might want to wait for the new 320/330D? |
IIRC diesel is taxed @ a slightly higher rate as well.
Sent from my MB525 using Bimmer App |
According to the www.fuelly.com data, which may be as good as any since it is reported using fill-ups and odometer readings, a 2011 335i gets on average 21.5 mpg while a 2011 335d gets on average 30.8 mpg. If premium fuel was $3.75 a gallon, then diesel would need to be (30.8/21.5)x($3.75)=$5.37/gallon for us to BREAK EVEN on the price.
By similar calculations, my last diesel car, a 2005 Mercedes E320 CDI saved me around $10,000 in fuel alone over 200,000 miles ownership. That would have paid for a lot of repairs had I had them! I did sell the car for a couple of thousand more than if it had been a gasoline V8, which is what the diesels should be compared to, not the gasoline V6 usually anyway due to their monster torque! Too many people in the US don't know how to do simple Math! PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck |
I have spent over $10k in repairs in less than 24 months on my diesel truck, $5.4k or so in just 2-3 weeks time. My brothers gas truck that is the same basic truck as mine has had I think $2k in repairs for same time and miles. I'd have to go digging to compare the 300SD to the late 380SE or 500SEL that all were 1985 models. Would have to go digging to compare the old Chevro let down trucks too. But bottom line, my experience has been that my diesel cars and trucks have cost me a lot more in repairs/maintenance for 200-300k miles than the gas sisters I or my family have had.
--Aaron |
Thankfully, I did not buy BMW X5 35D for their reliability.Gasoline engine has gotten really good these days. You can go on for 100k miles without problems. My brother's Honda CRV just turn 100k and still working well. 200k miles is very likely if they decide to keep the car. Their cost of ownership? Pretty much just your standard maintenance. In effect, the technology and market demand has closed the gap between diesel and gasoline to the point that most users don't see a difference. What is more important as a difference is the cost of fuel. Even with 30 cents to 40 cents adder, I still beat regular price by a few cents thanks to Diesel's 15% more energy content per gallon. It is a small win but a win nevertheless. X5 35i certainly can't live with regular fuel. That is really its nearest competitor. |
http://www.edmunds.com/autoobserver-...-adopters.html
Gasoline engines are coming around to using high pressure fuel pumps and direct injection - a technology that diesels have had for a long time and that requires problematic fuel pumps as in the recent problems with 335i pumps. There is one difference: diesel fuel is still a lubricant, gasoline is not. BMW is one of the most respected manufacturers of diesel engines in the world, makes a large number and variety, and should not disappoint with the 335d. Its one thing to have anecdotes, but another to have real data. PL
--Aaron |
Henry, the X5d does have some "near competitors". The new Cayenne diesel, the T-egg and Audi TDI and of course the ML/GL bluetec. Also coming down the road is the new Jeep GC diesel - 240 hp 420 lbs of torque. Which is about what all the new ones are rated at give or take a hp or lb or two. Lots of choices out there and it is even getting better as more and more come on line and get approved for sale here.
If you are near a Porsche store it is worth your time to stop in for a test drive of their new diesel. Amazing!
--Aaron |
#25
The only issue I've had with my 2003 Dodge/Cummins in almost 125,000 miles is the lift (low-pressure fuel) pump failing. I replaced it with a FASS system which cost about $500, IIRC, but the stock replacement was much less than that. I also had a 2002 Jetta TDI for about 128,000 miles before the 335d, and the only issue I had with that was one of the window brackets breaking, allowing the window to fall into the door. It was fixed under warranty. It was sold to an acquaintance of my son, and last we knew, it was still going strong with over 200,000 miles on it. All of the gasoline vehicles I've owned have been far more problematic, although to be fair, we haven't had a gas car since 2002. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
