Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
If Your Rim Is Out-of-Round, Will You Know?
Pretty much what's going on is...I have a moderately bad shimmy in my steering wheel. When it happens varies between 50 - 70mph. Past 70mph, it seems to stop...and under 50mph, it just doesn't do it.
I've tried rebalancing the tires. The air pressures are symmetrical. The only thing I can think of is maybe one of my rims are out-of-round? My left front tire has a very slow leak. It's had it since I put the tire on the rim (months ago). Instead of fixing it...I took the lazy route and just kept filling it up every 2 weeks. Sometimes it would be super low (maybe 10psi?), and I'd have to drive it to the gas station to fill it up...and I'm hoping that didn't bend the rim. Looking at the rim, I don't see anything wrong with it. Which leads me to ask... If your rim is out-of-round, will it be noticeable? Or is there a chance it can't be caught by the eye? Thanks. |
It's just weird how it's happening. When I got the new wheels, I put balance beads in the tires. It drove okay...wasn't a big fan of the balance beads, but they worked alright. A month later or so, the vibrations got worse. So, I went and put weights on the wheels. It drove really well. Months later, it's acting up again. Car has 72k miles. Last edited by Hemorrhage; 11-18-2012 at 12:18 PM. |
Another thing to add...
Can aluminum wheels even go out-of-round? If you were to hit a pothole or something...wouldn't it crack rather than go out-of-round? |
I have a feeling it is a bent wheel. Is there any vibration when you apply the brakes at any speed?
BurgerTuning.com - BMW Performance Specialists ![]() JB4 | LED Angel Eyes | BMW Oil Catch Can | BMW Jack Pad | BMW LED Trunk Lights | BMS Power Box | BMS N55 Intake |
However, I concluded that it isn't the wheel. I put on my stock rims, and the shimmy is still there at the same speed range. Could a bad tie rod be the culprit? Unfortunately, I don't have access to a jack to verify...but it'd be nice to know if it's something to consider. |
Was there a weird wear on the pads? |
