Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series / 2 Series > E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135.
Old 11-22-2012, 12:37 PM
PrincessSarah PrincessSarah is offline
Mein Auto: Series 1
Exclamation Pull Back & bunny hopping
So here goes (im a girl so bear with me)
A few weeks ago I noticed the odd judder when driving, but initially thought it may be some heavy wind captured under the car. However it has since got worse.
The orange warning light of a triangle with arrow around it comes on when the car pulls, on and off constantly at the moment causing the car to bunny hop, slow down etc.
I am just able to ride through it by switching gear, often going a bit too fast for the gear I am in (a bit too much throttle) but my car is definatley not well.
My mechanic cant see my car until late next week, and even then needs to keep it for a few days.
I know I just cant drive it at the moment but happy to roll up my sleeves and attempt some self help remedies as long as I have full instructions on how to do so.
Any help or tips would be much appreciated as I am just foreseeing the worst with plenty of ££££££ to follow
Car info:
Unleaded
Series 1
2004
95,000 miles on clock
Old 11-25-2012, 07:03 AM
thumper_330's Avatar
thumper_330 thumper_330 is offline
Send a message via Yahoo to thumper_330 Send a message via Skype™ to thumper_330
Mein Auto: 2012 K1600GT, 2012 135i
That would be your traction control kicking in.
Either you're being a bit rough on the accelerator, or your tires are bald... or just not inflated properly. Obviously the last is the easiest to check, but while you're at it check the tread depth. You might need new tires, but as I said it's equally possible that the tires aren't inflated properly as that can cause the tires to deform and kick in the traction control.
The colder weather doesn't help either; spots of ice might be a problem depending on how cold it is in your neck of the woods right now... but more likely it's the tires themselves. Oh, and check if they're summer tires; many summer tires become like hockey pucks when it gets cold, particularly run-flats.
Hope this helps
2001 E46 BMW 330i Sport Package 6MT *SOLD*
2004 BMW R1150GS - *SOLD*
2004 E60 BMW 545i Sport 6MT - *SOLD*
2012 BMW 135i - Deep Sea Blue / Terracotta / DCT
2012 BMW K1600GT - Vermillion Red Metallic
http://www.driveblog.net
Old 11-25-2012, 03:48 PM
ws6616 ws6616 is offline
Mein Auto: 97 Toyota Camry
im not a bimmer owner but i'd like to give it a try. my guess is uneven tire pressure; when temperature drops, tire pressure tend to drop too and when temperature rises, tire pressure rises.
just have it checked out and inflate it as needed.
remember:
1. don't check your tire pressure after driving; do it when the tires are cold.
2. check your tire pressure when there's a dramatic temperature change
Old 11-30-2012, 02:29 PM
mookjohnson mookjohnson is offline
Mein Auto: '11 E88 135 6 Spd
Could also be a slightly bent rim. I had a bent rim and didn't know it until one day I heard a strange growl and vibration at certain speeds. upon acceleration, my traction control light lit up. Thought the egine had problems but it was just a bent rim.
Current: '11 135 E88//6 Speed//Silver//Black//M Sport//Prem//Cold//Sat//Smrtphone Int
2008-2010: '08 335i E93//6 Speed//Monaco//Saddle Brown//Dark Burl//Sports//Cold//CA//Sat Radio//ED
2005-2008: '05 330 E46cic//6 Speed//Jet Black//Black//Sports//Nav//Cold
