Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 11-22-2012, 06:46 PM
whazzup whazzup is offline
Mein Auto: Lexus, Volvo
Winter tire package question
I bought a winter tire package from Tire Rack for my 2012 335 Cab and have noticed that the tires ride "rough" first when cold. Then they seem to "warm up" and ride smoother after a few miles. I have the LM-25 RFT's. Is this normal for the tires to have to "warm up"? I gave it a couple hundred miles, and it is still happening.
Old 11-22-2012, 10:06 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
depending on the tire construction, this is normal, its called flatspotting. some tires are more prone to it than others.
check your inflation pressures to make sure they are at spec.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 11-23-2012, 06:31 PM
I inflated tires according to BMW recommendations. Do I need to change that for the winter tires?
2015 F36 428i xDrive Gran Coupe
2012 e93 335i (Gone, but not forgotten)
2011 Lexus RX 350 (our workhorse)
2012 Volvo S60 T5
2010 e60 535i xDrive - Sold
2006 Volvo XC70 - Sold
2004 Lexus GX 470 - gone, but not forgotten
Old 11-25-2012, 08:31 AM
asus389 asus389 is offline
Mein Auto: 2011 328i
I found the LM-25 RFTs to flat spot a bit.
Old 11-27-2012, 08:33 PM
OK. It's annoying, but I can deal with it if its normal.
Still need an answer. Do I use the same inflation pressure as stock even though it's not a staggered set?
