E36 (1991 - 1999)
Old 11-22-2012, 06:55 PM
E36blownpast E36blownpast is offline
Mein Auto: E36 325i
325i m3 conversion
Mmmmmmmk so I have a 1994 325i that I am dropping the m62 into. But before I can actually put the motor in I have to upgrade my suspension. Now my question is...does the suspension from the e36 m3's simply just bolt on to the other 3 series of this generation or will I end up buying all relly expensive suspension from tein or somthing...
Old 11-22-2012, 06:59 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
thre are differences between the //M and standars suspensions, so struts from a non-m will not fit an //M. iirc the knuckles are slightly different and the sway bar links mount differently. cannot remember if the lower control arms ar the same or not, either.
however a quick search will be able to give you the answers.
can you bolt up an //M suspension tothe non-m chassis?? yes, but you will beed to get all of the related parts to be able to have it match properly.
there is a thread about how bmw's are like legos, so that is where i would start to learn the differences and such.
good luck.
df
Old 11-22-2012, 08:41 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
As far as struts are concerned they will all bolt up every which way whether M3 or 318. Only difference is the sway mount like DF mentioned, but that is really only a concern for M3 guys going to a suspension from something lower.
Non-M sways attach to control arms, and M sways attach to struts.
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 11-22-2012, 09:51 PM
hornhospital's Avatar
D'oh, You Kids!
Here:
http://jj100d.blogspot.com/2011/03/e...ike-legos.html
Quotes to live by:
Old 11-22-2012, 10:10 PM
Mein Auto: E36 325i
Thank you for the advice and the link it was reply helpful
Old 11-23-2012, 03:16 PM
helpful??....helpful!!!??
well we sorta mess up like that once in a while...wait till ed gets in on this. we'll be back to 'normal' then...
df
Old 11-23-2012, 05:23 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
M3 suspension may not really address the need from your engine swap. The M62 weighs about 480 lbs vs. 425 for the M50 vs. 365 for the M52.
You might want to look at some coil overs so you can have some adjustability in the front ride height to compensate for the extra engine weight.
The M3 spring height is a bit lower and they have a slightly different spring rate, but that might not completely compensate for all the weight you're going to add.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 11-23-2012, 06:53 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
365 for the M52? That's gotta be for the M52tu, right?
1998 BMW 328is
1966 Pontiac GTO
Old 11-23-2012, 07:02 PM
dc_wright's Avatar
It's for the M52 everywhere except the U.S. We're the only market that got cast iron block M52s I believe. I think TUs are double VANOS if I remember correctly. I don't remember at the moment if the TU got the aluminum block too.
Old 11-23-2012, 07:33 PM
Mein Auto: E36 325i
So instead of the m3 suspension I should just stick with coil overs?
Old 11-23-2012, 07:42 PM
dc_wright's Avatar
That's my opinion. I think you'll wind up with a better suspension for what you're trying to do. You have a wide range of choices in both performance and cost starting with Rokkors to Bilstein PSS-9.
Old 11-23-2012, 08:06 PM
Mein Auto: E36 325i
Ok that is what I shal do then...would an air ride system possibly be a good option then or should I just do coilovers
e36, m3, m62, suspension
