Old 11-23-2012, 11:26 AM
jeffrey0509 jeffrey0509 is offline
Mein Auto: BMW 328I
Angry Poor sound quality on satellite radio in new BMW
I have a new 2012 328I. The satellite radio sounds "tinny" almost like your underwater. Regular FM sounds fine as do CD's etc. I have heard from others that the problem is with Sirius and the amount of compression in their sound files. I don't believe this to be my problem because I have satellite radio in my home and the music sounds absolutely perfect. Are others experiencing this problem? I took the car to my dealer and the service manager listened to the radio but did not feel there was a problem. He said they would still remove the unit and check it out but I will wait to hear back from others before pursuing this option. Thanks
Old 11-23-2012, 12:25 PM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
has always sound bad in every bmw i have owned. satelite quality is just poor.
F30 328i Alpine White/coral red Msport 6MT, HK, Xenons, Msport brakes, black grills and side sills, performance exhaust
Old 11-23-2012, 01:40 PM
samualcc samualcc is offline
I probably dislike you...
Mein Auto: 2013 328i Sport
Sirius is aweful. Maybe the receiver has something to do with it, but nothing is wrong. It is just bad.
2013 BMW 328i Sport - Back in the family!
2007 Honda Civic Si Sedan (Retired, Meh)
2005 Infiniti G35 Coupe 6MT (Retired, great car)
2002 325xi (Retired, very much missed)
Old 11-23-2012, 01:59 PM
jmsent jmsent is offline
Mein Auto: 07 335i Coupe
Don't bother having them remove the radio. It's the signal from Sirius that's bad. When you say you have satellite radio at home, exactly what do you mean? You can get Sirius/XM off the internet or from some TV satellite systems. This is not the same as getting it off the satellite for your car. Also, turn off the surround option on your car radio. That just makes it worse.
Sold-07 335i COUPE-SPACE GRAY-STEP-SPORT-PREMIUM-COLD-SIRIUS-RFT DELETE
Old 11-23-2012, 02:01 PM
hans007 hans007 is offline
Mein Auto: 2013 328i m-sport EB2
sirius is 56kpbs or something on a codec that is maybe WMA level good. it is a 10 year old codec.
that said i can't imagine it being much different than FM. i dont have a BMW yet, but i've had XM in an acura and sirius in my current audi and it seems to sound "ok". i wouldnt say it was CD quality, but its definitely on par with FM
Old 11-23-2012, 02:29 PM
FM is analog. Its audio quality potential is more akin to 12 bit linear PCM sampled at 30kHz. Much more data than Sirius. Of course, FM stations are purposely compressed, but you don't get the high frequency artifacts of low bitrate digital-that "underwater sound". XM uses a very different format and to my ears sounds slightly better than Sirius. I'm also told that different bit rates are used in Sirius depending on the station in question and that some are substantially less than 56kb equivalent. In any event, for any of us who have been listening to Sirius for years, there's little doubt that it's terrible and that the OP is just discovering this fact. To my ears, most FM sounds better overall than Sirius.
Old 11-23-2012, 02:46 PM
Elk Elk is offline
Mein Auto: ~
This is indeed the case.
Some stations are also higher bit-rate, in particular the classical stations and, interestingly enough, Salsa. Salsa is higher rate as the deficiencies in the CODEC are most apparent with percussive sounds; classical, as many classical aficionados are more critical listeners.
I have not yet heard a Sirius station which even vaguely approaches the quality of a decent FM broadcast.
Old 11-23-2012, 04:28 PM
Mein Auto: BMW 328I
Thanks for all the responses. I am not convinced it is simply a problem with Sirius. My home satellite radio is a tiny XMp3i that sits in a docking station. It is connected to a Bose music system. But irregardless as to what it is connected to, I can use it as a portable device with headphones and it still sounds equally great - no underwater sounds, no tinny sounds. So you need to explain to me why the same signal source can have that much of a difference unless the car unit decoding the signal is at fault. Please lets' hear from others with a similar problem so I can go to BMW with factual ammunition to get this problem resolved, not only for me but apparently for others with the same problem.
Old 11-23-2012, 04:40 PM
SamS's Avatar
SamS SamS is offline
Mein Auto: 2013 ActiveHybrid 3
Trust me, there is nothing wrong with your Sirius in the car. The sound quality is going to suck, period.
If you don't like it (I don't either) then vote with your wallet and don't renew it.
Old 11-23-2012, 04:44 PM
justinnum1's Avatar
people dont buy sirius for the sound quality...
Old 11-23-2012, 05:01 PM
Elk Elk is offline
Mein Auto: ~
So you need to explain to me why the same signal source can have that much of a difference . . .
Because the BMW system, while limited in absolute terms, has greater resolution than the XMp3i and the equipment with which you use the XMp3i.
As others have stated, there is nothing wrong with your car. There is however a great deal wrong with Sirius.
Old 11-23-2012, 05:30 PM
jfox335i's Avatar
jfox335i jfox335i is offline
Mein Auto: 2014 335i
Sirius sounds fine in my F30. It doesn't have the quality of the IPhone or CD, but it sounds on par with FM. Agree with what was said earlier about turning off the L7 surround. Since I did that and adjust the EQ/bass/treble settings and set it back 2 spots to the rear, the HK sound is decent.
Current: 2014 F30 335i Melbourne M-line, PP,CW,6MT,NAV,DA,403M
2012 Z4sDrive35i - BSM,Coral Red,Msport,PP,Tech,CW
Retired:
2012 F30 335i Sedan - BSM, Sport Line, PP,Tech,HK,CW,DA2
2010 E90 M3 - JBM PP,TP,ES,CW,Beast
BMWCCA #471315
Old 11-23-2012, 05:43 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
+That's why I can't understand why some insist on putting it in at their cost. Unless they're interested in talk programs.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 11-23-2012, 05:50 PM
EddieB's Avatar
EddieB EddieB is offline
Mein Auto: '13 335i M-Sport 6sp
+1 If i want classical music I tune to my local HD FM station.
F30 Sapphire Black 335i 6MT|2PE|4AB|ZDH|5AC|LCSW|ZMM|ZPP|ZCW|ZDA|ZDB|ZTP|4 15|688 Dinan Stage 1 Suspension and Shockware ECU tune
Previously - F30 335i, E46 M3, E39 530i, E46 325i
Old 11-23-2012, 05:52 PM
EddieB's Avatar
cheers
vern
I got it in my other Bimmer so I could listen to the newest Alt Rock. It hits there much quicker than mainstream FM. I can't always get the college stations either.
Old 11-23-2012, 06:23 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
I think the Sirius sounds worse with the Harman Kardon sound system than it does with the base sound system. The HK is a premium system, and the Sirius is a lower quality signal than many commercial FM stations. As they say, "garbage in, garbage out".
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 11-24-2012, 12:32 PM
First off, consider the first 2 letters of your home satellite radio: XM. That's not a Sirius radio, it's an XM radio. As I already posted, the XM system is not comparable to Sirius, even though the programming is essentially the same. There's nothing BMW can do about the bad sound quality of Sirius. I've had many a rental car with Sirius on it, and the sound quality is always like this, regardless of make or model. You're just wasting your time with your "crusade", and risking that the service center will just ding up your dash while removing your radio.
Old 11-26-2012, 07:08 AM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
I thought I was the only one that could hear the difference between XM and Sirius..
My last car was a G35X with XM. XM did sound better and had less compression artifacts. I never knew Sirius had different compression depending on station. This explains why some stations sound really bad to me ears. I thought it was just a particular song or my imagination.
Thanks for the info. Helps a lot. Wish I could go back to XM. I agree the OP is just discovering the downside to Sirus as I had when I first got this car.
I also strongly agree the listening quality depends on the stereo. I can tolerate lower quality on earphones because you can't hear the artifacts as strongly. Not true on my home stereo or any car with a decent stereo.
As for why we might buy Sat radio...... We have horrible FM stations in my area, no FM HD music at all and bad enough cel coverage that you can't realistically stream music. While my 120Gb IPOD does have a lot of music, sometimes I just want to put something on without having to choose.
Old 11-26-2012, 10:21 AM
EddieB's Avatar
I do notice the traffic/weather station is really compressed. Classical sounds better than most rock stations.
Old 11-26-2012, 11:01 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
1) your XMp3i is not getting the same signal as your car. its using the XM frequencies and codecs
XM runs over 2332.50 through 2345.00 MHz
Sirius runs over 2320.00 through 2332.50 MHz
2) now that we have that out the the way, sirius uses a crappy codec vs xm. sirius uses PAC vs XM using AAC.
3) IIRC, sirius uses lower bit rates than XM
the poorer codec and the lower bitrates is why your XM radio sounds better than your car. sirius just sucks. years ago, it sounded better, but a few years back they lowered the bitrate of the stations to squeeze more channels in.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 11-26-2012, 02:30 PM
jtuds jtuds is offline
Mein Auto: 335i after May ED
cheers
vern
Howard Stern, NFL Radio, NFL and NCAA Play by Play
Old 11-27-2012, 08:05 AM
shabadoo25 shabadoo25 is offline
Mein Auto: 2008 335i
For all the technical reasons listed above, XM's sound is superior to that of Sirius's.
XM has better higher end sound. Sirius has an increased lower end as a form of compensation.
Also, the aftermarket and especially recording units usually had better sound than factory and/or in-dash units.
So at the end of the day, there are a lot of reasons why your BMW Sirius doesn't sound as good as your XMP3i.
2012 Alpine White F30 328i Leather Dakota Everest Grey/Sport Line/Premium/Premium Sound/Technology/STEPTRONIC/Rear View Camera/Heated Front Seats/Park Distance Control/Xenons/BMW Assist w/Enhanced USB/BMW Apps
Old 11-27-2012, 09:49 AM
pawarrant pawarrant is offline
SECDEF
Mein Auto: 2013 Melbourne Red 328xi
This is a bit off topic, but do different car manufactures get different stations and packages? My parents have a Lexus and they get several channels that I do not get on my new BMW. Specifically the Lexus gets chan. 014, 015 and some others I don't receive on mine.
Old 11-28-2012, 05:09 AM
All the Asian cars have XM, not Sirius. While the content is 95% the same, the channel numbers differ in some cases.
Old 11-28-2012, 07:55 AM
NewToCarBuying NewToCarBuying is offline
Mein Auto: AH5 "13
Than put in your own smartphone integrated music if you don't like the XM
Its unfortunate it happens on every car
Thanks to satelites!
