Old 11-24-2012, 02:51 PM
CeeJay71 CeeJay71 is offline
Mein Auto: 1997 540I
Oil change
Is there anything done differently from other car oil changes
Sent from my ADR6400L using Bimmer App
Old 11-24-2012, 03:19 PM
gomolka30 gomolka30 is offline
Mein Auto: 2001 530i
No, unless you are unfamiliar with canister type filters.
Old 11-24-2012, 03:39 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You'll need to back out the black cap on the canister until it just clears. This allows the oil to drain back into the sump.
The filter cartridge comes with a new O-ring and washer for the oil pan plug. No need to hog down on the cap - just make sure it's firmly seated in the canister. Most of us use German-made filters, like Mahle or Knecht.
You'll need a 36 mm socket, and a bolt measuring 6x1.0x40 mm. The bolt screws into the side of the canister, and by holding it with your other hand to counteract the torque while removing/replacing the cap prevents damaging the rubber shock mounts.
Old 11-27-2012, 04:39 PM
seemyad's Avatar
seemyad seemyad is offline
BMW ****ie
Mein Auto: 530i Sport Package
I installed a magnetic oil drain plug during the oil change. Hopefully it will trap metal shavings over time.
Magnetic Drain Plug
http://www.drainplugmagnets.com/bmw.php
Intersting Video on Magnet Manufactuer Webpage
http://www.drainplugmagnets.com/videopresentations.html
BAVAUTO Review June 2012 -
"Here at Bavarian Autosport, we've been using and recommending the Dimple Super Magnetic Drain Plugs since our first evaluation and testing of them. These are the highest quality and strongest magnetic drain plugs that we have ever used or tested...."
http://blog.bavauto.com/11544/bmw-an...r-review-test/
Old 11-28-2012, 12:10 AM
- BMW approved motor oils (pdf) & tribal motor oil recommendations (1) (2) (3) & gravity oil change DIY (1) (2) (3) (4) (5) & vacuum extraction DIY (1) (2) (3) & drill pump DIY (1)
