Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 11-23-2012, 11:13 PM
kskane kskane is online now
Mein Auto: 2004 BMW 525i Auto
Smile Oil Filter Housing Gasket - Replacement (M54)
Refer to the PDF and if anyone has any problem with the file, let me know and I will post it again. This DIY is for 2004 525i with M54 engine.
File Type: pdf DIY - Oil Filter Housing Gasket Replacement.pdf (1.66 MB, 378 views)
Old 11-26-2012, 06:33 PM
langstisthebb langstisthebb is offline
Mein Auto: 535i
Very helpful! I was able to follow these steps and successfully complete the oil filter housing gasket replacement. Do you happen to have any instructions on replacing the heat exchange gasket? This is also leaking.
Old 11-28-2012, 03:10 PM
I'm afraid I don't, as I don't even know where is the heat exchange gasket? Are you referring to the cylinder head cover gasket?
Old 04-30-2013, 02:13 PM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2003 BMW 525I
Thanks for the DIY. Planning to tackle this along with the VANOS. Is there an RTV Sealant used along with the gasket? Or is it simply,
1 remove old gasket (scrape)
2 clean area for new gasket
3 install new gasket
- 2003 525I Sedan - Manual Tranny, M-tech Bumpers Front/Rear, shadowline, M5 Mirrors, 19" Miro 279's, NNR Coilovers, Front lip, 50% tint, Dinan ECU Stage II, Dinan CAI, Dinan Free Flow Exhaust, DICE Ipod, Connects2/Parrot Bluetooth, SSK Kit, AC Schnitzer Shift Knob, CDV Delete,
- 2008 R350 Mercedes Wagon
Old 05-14-2013, 06:18 PM
No RTV sealant is needed for OFHG.
Old 06-11-2013, 10:07 PM
BM109R's Avatar
BM109R BM109R is online now
Mein Auto: BMW E39
Excellent DIY. When I did mine on my previous e39, I found that in removing alternator, spraying a bit of wd40 at the contact points to the engine block makes it come out nice and easy with no jerking necessary.
Old 06-11-2013, 11:24 PM
Thanks for letting us know, I will keep in mind for next time
