Oil change
Is there anything done differently from other car oil changes
Sent from my ADR6400L using Bimmer App |
No, unless you are unfamiliar with canister type filters.
You'll need to back out the black cap on the canister until it just clears. This allows the oil to drain back into the sump.
The filter cartridge comes with a new O-ring and washer for the oil pan plug. No need to hog down on the cap - just make sure it's firmly seated in the canister. Most of us use German-made filters, like Mahle or Knecht. You'll need a 36 mm socket, and a bolt measuring 6x1.0x40 mm. The bolt screws into the side of the canister, and by holding it with your other hand to counteract the torque while removing/replacing the cap prevents damaging the rubber shock mounts.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. Last edited by edjack; 11-24-2012 at 02:49 PM. |
I installed a magnetic oil drain plug during the oil change. Hopefully it will trap metal shavings over time.
Magnetic Drain Plug http://www.drainplugmagnets.com/bmw.php Intersting Video on Magnet Manufactuer Webpage http://www.drainplugmagnets.com/videopresentations.html BAVAUTO Review June 2012 - "Here at Bavarian Autosport, we've been using and recommending the Dimple Super Magnetic Drain Plugs since our first evaluation and testing of them. These are the highest quality and strongest magnetic drain plugs that we have ever used or tested...." http://blog.bavauto.com/11544/bmw-an...r-review-test/ . Last edited by seemyad; 11-27-2012 at 04:17 PM. |
- BMW approved motor oils (pdf) & tribal motor oil recommendations (1) (2) (3) & gravity oil change DIY (1) (2) (3) (4) (5) & vacuum extraction DIY (1) (2) (3) & drill pump DIY (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
