Old 11-24-2012, 08:55 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2013 M5
Coding lighting
I coded some features today.
After coding, I noticed that when I switch off the car, the headlights switch off straightaway, instead of staying in for 40 seconds per the pathway lighting setting.
Has anyone else experienced this?
Also I coded the FLA_Aktiv feature to be on (M5 doesn't have this option) and this is also not working even though I changed the setting to automatisch. I don't know if these 2 things are related. The only other lighting mod I did was switching off side markers.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP
Old 11-25-2012, 04:05 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
What is the Pathway Lighting set for under the iDrive Lighting Options?
For AHB, BMW changed the behavior of FLA_AUTO_AKTIV from "aktiv" to "automatik", and now apparently the Lights need to be cycled before AHB works. You should read this thread if you haven't already:
http://www.bimmerfest.com/forums/sho...d.php?t=644297
wdimagineer retrofitted the stalk in his M5, which if I understood him correctly he still needs to cycle the lights for AHB to work, but it is easier from the stalk.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 11-25-2012, 07:09 AM
The Driver
Mein Auto: 2013 M5
I have pathway lighting set to 40 seconds.
Old 11-25-2012, 07:59 AM
Strange. I don't know of any other instance where this has happened.
Right Click in your FRM ECU (the ECU itself; not the underlying CAFD, and select CODE) to reset to your Footwell module, and see if it returns to normal.
- BMWCCA #446923
- flick
Old 11-25-2012, 08:48 AM
The Driver
Mein Auto: 2013 M5
I am wondering if I am using the right coding data.
I installed the 48.1 data you linked me yesterday. Then when connecting to the car, I selected F10. Is there a different selection for the M5?
Also it doesn't have HU-CIC it has HU-something beginning with L. It did strike me as odd that the files are different.
Old 11-25-2012, 08:53 AM
You have the right coding files. 48.1 is universally good, and F10 is the correct target for your new M5. Your HU_CIC is HU_NBT because you have the new iDrive system in your MY 2013. You also will not find a CMB_MEDIA or CMB_ECALL module, as your Combox functions are built into in the Head Unit, and not a standalone module.
- BMWCCA #446923
- flick
Old 11-25-2012, 12:55 PM
The Driver
Mein Auto: 2013 M5
Another issue I ran into was that I could not find ASP_Beiklappen_Bei_Komfortschleissen in the CAS file. Without changing this to aktiv I could not activate comfort access door mirrors.
Old 11-25-2012, 12:58 PM
What is the name of your CAS CAFD file?
- BMWCCA #446923
- flick
Old 11-25-2012, 01:24 PM
The Driver
Mein Auto: 2013 M5
I'll get back to you in 2 days. Just have a short trip to SAN.
Old 11-25-2012, 04:41 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: Coupe
This should be in the FRM module.
Old 11-25-2012, 07:12 PM
Good catch. I missed that.
- BMWCCA #446923
- flick
Old 11-27-2012, 07:00 AM
Sharbotcom Sharbotcom is offline
Mein Auto: F10 535xi MSport
Stealth:
Make sure your light switch is set on automatic.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, M Sport Package, 316, 322, 3AG, 5AD, 5AG, 5DL, 609, 620, 655, 677, 6FL delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
