E90/E91/E92/E93 (2006 - 2013)
Old 11-25-2012, 06:51 AM
Spudbum Spudbum is offline
Mein Auto: E93 320d Cabriolet
Comfort access. Have it or not?
Hi guys
First of all this is my first post so go easy on me and sorry if this has already been answered
It may sound like a stupid question, but i have just taken delivery of my new 320d e93.
If i go into the system settings and then to locks, i can select "comfort entry"
Does this mean i have the comfort access pack, and should i be able to get in the car without clicking the button?
Cheers
Dom
Old 11-25-2012, 09:22 AM
raleedy's Avatar
raleedy raleedy is offline
I paid for this airplane!
Mein Auto: 2008 E92 328i
Not necessarily. The tell-tale for Comfort Access is the outside handles on the front doors. With CA, they have ridges on the top. CA also includes a key fob that has a removable battery; non-CA cars have a fob with a rechargeable, non-removable battery.
Old 11-25-2012, 06:19 PM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
And for a definitive test, sit in the driver seat with your key in your pocket, press the brake pedal and push the start button.
Old 11-25-2012, 07:13 PM
raleedy's Avatar
Yeah, well, that's pretty definitive if it works; but if it doesn't start the car, that could mean one of two or three different things: (a) it's a manual shift car that may or may not have CA; (b) it doesn't have CA; or (c) it has CA but the CA isn't working properly (because of a depleted battery, or other malfunction).
Old 11-27-2012, 12:56 AM
Kristian Kristian is offline
Kris
Mein Auto: 2011 320d Coupe
http://bmwvin.com/?vin
If you go to the above site with the last 7 digits of your VIN, it will definitively tell you whether you have comfort access or not.
Old 11-27-2012, 08:51 AM
Tom K. Tom K. is offline
Although the OP has a newer model, my CA equipped '07 has no option for "Comfort Entry" under locks. The Comfort Access for entry and locking is always enabled, it does not have to be turned on. It simply involves grasping the door handle with the fob within about 6 feet of the car and the door will unlock. And as Raleedy said, there will be ridges on the door handle to lock the door if you have CA.
Also, I notice in perusing Porache's literature (just bought a Boxster) that they define "Comfort Entry" as an adjustment of the power seat (depending on key fob) to facilitate getting in or out of the car. The seat then returns to it's preset position. So perhaps the OP's Bimmer has that feature in conjuction with the memory power seats - with or without CA.
Tom
Old 11-28-2012, 04:58 PM
Ria Ria is offline
Mein Auto: 335IX
My '12 has CA and it works like the a fore mentioned Boxer
Old 11-28-2012, 06:40 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
My Reality Check bounced
Mein Auto: 09 328i 6MT Cabrio
Since OP has a cabrio, they have the option of not only Comfort Access but also Convenient Access. Convenient access is where the top will partly fold out of the way, but not fully inconvenience putting things in the trunk. AFIK, Convienient Access is only available if Comfort Access is installed. Bottom line unless an aftermarket add on such as the SmartTop module is installed, the only way to definitively know if comfort access/convienient access is present on the car is to look for the ridges on the door handle.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|CDV Delete|Shark Fin Antennae Delete|Front Reflector Delete|LUX H8 Angel Eyes|No Bells|Few Whistles|Das Fahren im Freien| BMWCCA#445793
